Old 11-30-2018, 11:58 AM   #1
Tootall
Default Identifying a Model A Engine
I have an engine that I think is a 1929. The Oil Pan is different than the one on my 1930. It has the rounded area for the longer pump tube with oil drain in the bottom of it.
It also has a Power House generator on it and I thought they were only put on the 1928 models. I recognize that someone could have added this unit. I would still like to know that this is a 1929 engine. I believe it was a service engine because it does not have Serial Numbers. Are there other identifying marks or features that one would use to be sure of year when looking at exterior of motor?
Tootall is offline   Reply With Quote
Old 11-30-2018, 12:06 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Identifying a Model A Engine
Oil pan is 1928, but the powerhouse was used until mid 1929.
Old 11-30-2018, 01:03 PM   #3
Brian T
Brian T's Avatar
Hi Tootall,
Go to Steve Pluckers web site and find the PDF titled Cylinder Block Change Discription, I used it to ID a bare block with no engine #, it was between March and August 1930.
Regards Brian. http://www.plucks329s.org/
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 11-30-2018, 01:53 PM   #4
Tootall
Thanks for the reply and the site info.
I appreciate it.
