09-24-2016, 02:51 PM | #1 |
Tachometer?
Should the Model A RPM stay under 3000?
09-24-2016, 03:38 PM | #2 |
Re: Tachometer?
I think so and I like to limit mine to 2000.
09-24-2016, 03:41 PM | #3 |
Re: Tachometer?
these are long-stroke, low-revving motors with boatloads of torque down low, you don't need to rev the nuts off it
'31 180A |
09-24-2016, 04:14 PM | #4 |
Re: Tachometer?
09-24-2016, 04:32 PM | #5 |
Re: Tachometer?
45 mph is about 2400 rpm.
09-24-2016, 08:48 PM | #6 |
Re: Tachometer?
Steve Hanna, Polk City, IA |
09-24-2016, 06:01 PM | #7 |
Re: Tachometer?
What do you guys use for a tach, and how do you hook them up
09-24-2016, 06:44 PM | #8 |
Re: Tachometer?
09-24-2016, 06:52 PM | #9 |
Re: Tachometer?
I bought a Bosch from Jegs, FST7906, 2 5/8" diameter, now $34.21. It mounts on the column.
nick c |
09-26-2016, 09:11 AM | #10 | |
Re: Tachometer?
If I'm wrong please correct me. I for one would like a tach, but a workable/usable one is a lot of dough
09-24-2016, 08:13 PM | #11 |
Re: Tachometer?
Have not hooked one up myself but I'm sure someone here will be able to explain how it is done on a Model A.
Dave / Lincoln Nebraska |
09-24-2016, 10:21 PM | #12 |
Re: Tachometer?
I use a "Tiny-Tach".
It is a small digital tach that will mount almost anywhere. All it needs for a hook up is one wire that is grounded and a second wire that wraps around the coil wire. I like to run the engine between 1750 and 2000 RPM while on the road. I limit the engine to no more than 2300 RPM for short periods of time when pulling a steep hill in the lower gears etc. I find a tach very helpful and it is fun to watch the speed of the engine. My opinion, Chris W. |
09-26-2016, 09:15 AM | #13 | |
Re: Tachometer?
Pics of the hook up and mounting would be helpful also
09-24-2016, 06:35 PM | #14 |
Re: Tachometer?
Why do you need a tach on a Model A? Like everyone says, they are a low rpm engine. I cannot imagine why a tach would be useful or necessary in normal operation.
09-24-2016, 08:00 PM | #15 |
Re: Tachometer?
TACHS are for show. I drove manual tranny cars exclusively for the first 30 years of my driving and never used them... I looking forward for the 2018 jeep pick up and 6 speed manual --on my list.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
09-24-2016, 08:59 PM | #16 |
Re: Tachometer?
I have the tach Snyders sells and it hooks up off the coil. Easy to do. As said, no need for one for most driving but that is an individual matter. Get the 0-3500 one. The A engine can handle over 3000 rpm, but again, not much need to do so in normal driving. They are tough engines.
09-26-2016, 10:06 AM | #17 |
Re: Tachometer?
I don't remember where I bought these but they are VDO gauges. I have a full pressurized engine to go with the oil pressure gauge.I believe the tach is 12v neg ground. It can be set for 4, 6 or 8 cylinders. I think I got them from Summit Racing.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
09-26-2016, 11:21 AM | #18 |
Re: Tachometer?
09-26-2016, 11:49 AM | #19 |
Re: Tachometer?
Here's mine:
09-26-2016, 02:40 PM | #20 |
Re: Tachometer?
I have a Tiny Tach mounted in my car and it's small and easily mounted.
The response to revs is a bit delayed, but it does show you what revs you are doing and has an hour meter as well. As I recall they are cheap too!https://www.tinytach.com/ Keith |
