08-14-2012, 01:15 PM | #1 |
Used new rust product
used new rust product called Phosphoric etch and prep and worked awesome. Sprayed on the hood and let set over night.
08-14-2012, 01:52 PM | #2 |
Re: Used new rust product
Not really new,it's been around for years.
08-14-2012, 08:09 PM | #3 |
Where did you get it from? Is there a brand name? I just got a 50 F4, and could sure use something.
08-14-2012, 08:17 PM | #4 |
Phosphoric etch and prep. Home depot 15.00 a gallon. Used about 8 ounces on the hood. Let it sit over night and just washed it off next morning. Was real good and prime or spray some on a towl and wipe on so it won't flash rust. Used a dollar spray bottle from home depot.
08-15-2012, 04:31 AM | #5 | |
This stuff is great for cast iron exhaust manifolds & the like .soak them for a day or two in a heavier concentrate. Goes kind of black looking until you pressure blast off with water, Dry em fast with compressed air afterwards then coat with spray wd40 or similar , should Look like new cast iron afterwards. Alloy parts should not be left too long as they will be eaten away to nothing. |
08-15-2012, 11:17 AM | #6 | |
08-15-2012, 11:29 AM | #7 |
Keep in mind, the stuff needs to stay wet to work. For long periods of derusting you need to place some cloth on the area and keep it saturated.
