Old 10-26-2021, 05:08 PM   #1
duke36
Default Slant Window wiper Installation
Is there a special spacer surrounding the wiper shaft that passes thru the wood header, and if so, does the wiper compress on the interior fabric header panel or somehow on the spacer to prevent the wiper from rotating ?
Old 10-26-2021, 10:58 PM   #2
jw hash
jw hash's Avatar
Default Re: Slant Window wiper Installation
no spacer the wiper motor is pulled up tight to the interior header panel. I have found that under the outside header cover there was a felt seal. I use a small rubber washer and a stainless washer and a chrome nut to seal the shaft where it comes out of the header cover.
jw hash is offline   Reply With Quote
Old 10-27-2021, 10:51 AM   #3
JD-OHIO
JD-OHIO's Avatar
I would like to see pictures of the wiper from inside the car and outside the car. My Slant Window TS has no wiper at all just the hole on the outside metal piece above the window.
JD-OHIO is offline   Reply With Quote
Old 10-27-2021, 04:43 PM   #4
Bill Cilker
Bill Cilker's Avatar
JD
Here are your pictures. They are from my unrestored Victoria. The wiper would be the same on a 160 sedan
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 10-27-2021, 05:07 PM   #5
Gene F
Gene F's Avatar
A 1/2 piece of copper tubing, a flat washer perhaps???
Old 10-27-2021, 06:24 PM   #6
JD-OHIO
JD-OHIO's Avatar
Originally Posted by Bill Cilker View Post
JD
Thank you.
Old 10-27-2021, 06:50 PM   #7
Oldbluoval
Oldbluoval's Avatar
I think what I’ve seen on old unrestored cars was an outside lead or pot metal type washer
But no pic documentation
