Old 01-07-2012, 08:49 PM   #1
Brian T
Brian T's Avatar
Default Siezed Moto Meter
Has anyone had to remove a seized MotoMeter, I have removed the lock screw and tried to turn it with a strap wrench, it wont budge, I dont want to use any fluids such as PB blaster in case it harms the paint , maybe a little gentle heat ?.
Thanks in advance Brian T.
Brian T is offline   Reply With Quote
Old 01-07-2012, 10:52 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Siezed Moto Meter
Brian, I'd probably try a hair dryer, as it wouldn't be hot enough to harm anything.--Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-08-2012, 12:08 AM   #3
sonny30coupe
Probably wouldnt be hot enough to do anything either
sonny30coupe is offline   Reply With Quote
Old 01-08-2012, 11:11 AM   #4
85930tudor
85930tudor's Avatar
Send a message via Yahoo to 85930tudor
Try a little CLR like used in your shower worked on mine..Dave
85930tudor is offline   Reply With Quote
Old 01-08-2012, 11:47 AM   #5
silvertop
silvertop's Avatar
Brian,
I would cut open a garbage bag, cut a hole in it and put it over the rad opening then wrap some rags around the opening to protect the paint. Now go at it with the PB Blaster and a heat gun. If that doesn't work see Jeff.
The only thing that can beat an attempt----is a failure!!!!
silvertop is offline   Reply With Quote
