Old 09-12-2020, 03:20 PM   #1
56sedandelivery
56sedandelivery's Avatar
Default Air intake sealer
What do you use for sealer around the freash air intake tube? Looked like old tar that I scraped off. Hard as a rock.
56sedandelivery is offline   Reply With Quote
Old 09-12-2020, 03:54 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: Air intake sealer
Any good body sealer would work fine.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 09-12-2020, 08:05 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
When I did the body-off-frame resto on both my '55 Fairlane and my '55 Courier, I got a sheet of foam gasket material from local auto store and cut-out gaskets using the bottom flange of those air-intake elbows as a pattern. Then I cut out two more gaskets exactly same for the ducts on the inner fender apron.
After assembling the painted elbows to the painted firewall with the gaskets sandwiched between, I then got a glob of "Duxseal" and smashed a gob over and around the four mounting bolts that hold the elbows to the firewall so water can't get between the bottom of the bolt-head and elbow flange and run down inside the car. You could also use a bathtub caulk or "Vulcan" caulk instead of "Duxseal", but that would be real messy and ugly.
Old 09-12-2020, 09:55 PM   #4
packrat5
A 2-component body sealer. It's pretty much permanent, and impervious to everything. 3M, Fuzor, Norton, PlioGrip, they are all pretty much the same, all cost the same, (somewhat pricey) but they work equally well. Meaning great. Norton is my personal go to. It should be used on bare metal for the best results, and can be painted over with anything at all.
Those ducts have to be sealed very good, as any water you may drive over, will get drawn into the heater system, and fog up the windows.
packrat5 is offline   Reply With Quote
