12-01-2018, 09:35 AM | #1 |
1957 e-bird vacuum
I was wondering if anyone can tell me the proper way to connect up the vacuum lines from the distributor to the (2) holly teapots on my 1957 t bird. Right now there is no vacuum line to either carb. The car is a 3 speed with an over drive. In addition, this t-bird appears to have the carburetors rotated 180 degrees from what I have seen in pictures, I was told that this was required in order to allow the air cleaner housing to clear the hood scoop.
12-01-2018, 12:12 PM | #2 |
Re: 1957 e-bird vacuum
Sorry, I cannot help with vacuum line diagrams. I only have a diagram showing how to hook up the gas pedal linkage.
12-01-2018, 12:27 PM | #3 |
Yes, the carbs on T-Birds are backwards compared to passenger cars. The vacuum to the distributor diaphragm goes to the rear carb only (I think). The front carb gets a threaded plug in the vacuum hole. The link below will have all of the correct lines for your car (vacuum and fuel).
Sal http://www.classictbird.com/ |
12-01-2018, 09:59 PM | #4 |
They also have a good tech area and will answer inquiries over the phone
12-01-2018, 10:36 PM | #5 |
This link goes to a pretty good picture of the fuel and vacuum lines on a '57 T-Bird.
Sal https://images.search.yahoo.com/sear...g&action=click |
12-02-2018, 05:25 AM | #6 |
The PASS CAR setup is shown but will detail the port location.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
12-02-2018, 06:51 PM | #7 | |
While Carousing With My Browser, I came across this- - 1957 BIRD E-CODE Right Side Shot -
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 12-02-2018 at 07:10 PM. |
12-02-2018, 07:18 PM | #8 |
May as well show the LS SHOT while I am here -
12-03-2018, 09:27 AM | #9 |
