01-10-2018, 09:30 AM | #1 |
Locked up engine update
My last post on thing was back in November. Finnaly got the car up on lift
as I thought starter really jammed had to destroy the dust cover then we got the bendex to move a little. I removed the starter housing so with hand on armature and with channel lock I got the armature and bendex out, sure enought the ring gear. we managed to punch ring gear back to its shoulder. Using a small level I marked the front pulley 9-3 12-6'o clock. We migged a mig dot 9-3 12 & 6 o'clock. Put all back together pushed the button 1/2 turn running but with donk donk and worse with the clutch in more like cluck cluck. Take starter out again I figure a weld dot may be striking the block, nope no shinney marks. Oh I did find armature shaft was bent .120 thou so that got tweeked and got .003 runout, good enought back together same ole noise & worse with clutch. Can't be crank end play this is all new with .004 end play. Going back, went for milk, shut her off (no noises no nothing) come out and thats all she wrote. ? is. how in hell does a ring gear take a ride while at idle walk out and jam against the block ?? This is a temporary eng. while the origional got bored. Next I will post 59A rod bearings..sam |
01-10-2018, 09:52 AM | #2 |
Re: Locked up engine update
Clutch cover fly weight?
01-10-2018, 10:52 AM | #3 |
Forgive me, bigjob, I find it hard to follow your posts.
Are you saying the ring gear walked off the flywheel after being knocked back and migged in 4 places? Migging steel to cast iron is probably not ideal, did the 4 welds break? It looks like you might need to use a better flywheel and ring gear combo. Mart. |
01-12-2018, 04:32 PM | #4 |
Big Job
X2 What Mart stated. It's hard to figure out what happened when you said that the ring gear took a ride after putting it back on . What happened? How did you fix the problem? |
01-12-2018, 05:38 PM | #5 |
