01-06-2018, 07:11 AM | #81 | |
Re: Building Some 1932'S - Come Along for the Ride
Im not sure how many lbs are @ the gun because euro FLG 5 has the little regulator at the bottom. So im kinda going by sound & feel. Yes to your question about like I said before. Im guessing 40 lbs at the gun for the first coat, even and wet. Then drop the pressure to about 33 ? When i can glide the back of my fingers over the edges without it sticking, they spray another coat. 2 coats total, fan opened all the way up to max, nice overlaps. overlaps are important more so because if you have one pass where you have some heavy orange peel youll need to re-coat again with a 3. Avoid that or the millage will be to much to lay all that paint on with out some dry time. Also, my buddy has an "walk in" oven for bending plastic that i warm the pcs up first, warm metal helps. Not HOT metal, warm metal... In the end i guess i probably make a couple more passes with the gun. Maybe if it would take 12 pass to get across a panel, i might do it in 18. Im not sure if i actually putting on more paint or not because the speed in which i make the passes is greater. Next time i spray something ill have some video it with my phone so you can see. Because you sound really interested and maybe your about to paint things soon? Last edited by Ian1932; 01-06-2018 at 11:09 AM. |
01-06-2018, 09:42 AM | #82 | |
Thanks! I am trying really hard to get this done in a short amount of time. I try to do one thing every day. Clean something, read something, prep something, learn something, etc. I realized there are so many things that at some point need to be done. Like the seats, they are ready to bolt in, the lights are all ready. Once the weather cooperates and I can build a chassis, I'll have stuff that's ready. I am certain that I'm going to need to make adjustments and need to re-paint something. I feel for me, it would be faster to go for it than to assemble the car and take it apart again. I sure hope that's minimal. With modern paint, it's so easy to repair and feather. Painting and prepping for me is the cake part when it comes to time spent. Things like setting up brakes and setting up cables and wires is going to really slow me down. I'm really depending on the guys on this site. At some point I'll be asking "what should I do now", when assembly starts. Thanks for watching! Last edited by Ian1932; 01-06-2018 at 11:05 AM. |
01-06-2018, 02:57 PM | #83 |
01-06-2018, 07:32 PM | #84 |
01-06-2018, 07:34 PM | #85 |
"Fenders in the attic"
01-06-2018, 08:35 PM | #86 |
01-07-2018, 09:37 AM | #87 |
Yeah, they are really nice. I remember when i was in 3rd grade +or- my mother would send me up there to get the Christmas ornaments and my dad would be down there "Hey, be careful around those fenders, dont stand on them!!!" That was about 33 or 35 years ago!
01-07-2018, 04:44 PM | #88 | |
your great progress! (I'm a hack, trying to teach myself and I like your "no peel method". Still, its all about practice, practice.......) |
01-13-2018, 01:32 PM | #89 |
Sandblasting, priming, sandblasting and priming some more, then painting and on and on for now...
I will never paint wheels with spokes again if i can avoid it...That was the most difficult thing i have ever done... Toilet bowl cleaner does work well to clean the inside of a tank. Takes about 6 hours and rust is gone on the inside. Now i will sand blast the outside... |
01-13-2018, 01:50 PM | #90 |
Hi Ian,
Nice job on the wire wheels! I hear you on never doing them again. I painted some of mine many a couple of decades ago and used a Touch-up spray gun and one part paint so no sanding after paint was required. They were a real pain to do. A couple of years ago they needed to be done again. I had them powder coated this time. First time the guy missed a few spots on two of them and told me to look at them after he was done. He did them over with no complaint and they were perfect this time. How many jugs of the toilet bowl cleaner did you use? Did you dilute it and did you fill the tank? |
01-13-2018, 02:07 PM | #91 | |
The wheels i missed spots and got a couple of runs. I had to go back and spray more touch-up paint and sand out runs and then rub out the marks. They actually look really good but it was a lot of work no doubt... |
01-13-2018, 02:30 PM | #92 |
Good, thanks Ian
01-13-2018, 03:13 PM | #93 |
If there is ever a next time, make up a simple rotisserie using a motor from an old barbecue. That slow rotation will eliminate runs and enable you to get both excellent coverage and flow out.
01-13-2018, 03:14 PM | #94 |
Great tip David.
01-13-2018, 04:08 PM | #95 |
Good idea...I have an old K car hub from an old trailer, all the studs were broke but one. I spun it on there but by hand. I would have be much easier to have it motorized no doubt...
01-24-2018, 06:08 AM | #96 |
Sand blasted, primed & painted...
01-30-2018, 08:21 AM | #97 |
Yesterday after work...
02-01-2018, 01:05 PM | #98 |
Tank is done...
02-01-2018, 01:07 PM | #99 |
Beautiful job!
02-01-2018, 01:33 PM | #100 |
