11-11-2018, 02:21 PM | #1 |
1935 Wire Wheels
Just remember, there's no such thing as a stupid question, just stupid answer's! Anyway.... I assume 35 V8 16'' wire wheels bolt onto Model A's with no modifications? Thanks in advance
11-11-2018, 02:39 PM | #2 |
Re: 1935 Wire Wheels
That is correct, direct bolt up.
Last year, I tried 16" radials on a 5700 mile road trip. I left my 21" wheels in the sidemounts as spares. The 21" wheels with standard A Firestones were the same diameter as the 16" wheels with the R700 Coker radials I mounted at the rear. The front radial shown was a smaller R600. The radials made a big difference in the ride. I change the wheels back to the 21" for local Club events but when we are on the road for a long distance the radials are on. Good Day! Last edited by Dave in MN; 11-12-2018 at 03:25 PM. |
11-11-2018, 03:24 PM | #3 |
Yes, if the Model A still has the mechanical brakes, if the Model A has later Ford hydraulic brakes an adapter is required. Remember you can put a 600-16 tire in the well if you let some of the air out and carry a pump.
Charlie Stephens |
11-11-2018, 04:45 PM | #4 | |
Sent from my SM-J700T using Tapatalk |
11-11-2018, 04:55 PM | #5 |
www.whidbeymodelaclub.com |
11-11-2018, 05:08 PM | #6 | |
Charlie Stephens |
11-11-2018, 06:35 PM | #7 |
There seems to be tons of '35 Ford 16 inch rims around I see them everywhere
11-12-2018, 12:02 PM | #8 | |
11-12-2018, 12:43 PM | #9 |
I've never had a problem with later wheels used on my model A's . I now mostly run original wheels . I feel that 1935 16 inch wheels ruin the look of an original model A !!!
