07-19-2018, 06:40 AM | #1 |
nu-rex cut out
I'm trying to wire my 30 deluxe coupe and I have a couple of questions. I have a nu-rex cut-out and I'm not sure where the wires go. I have a wiring harness from Rhode Island but I'm confused as to what side do the 2 yellow wires from the light switch attach to? Bat or gen? What side of the cut-out does the single yellow/blk wire that goes to the drivers side terminal box attach to? bat or gen?
Does it matter which terminal on the starter I attach the solid yellow wire to? |
07-19-2018, 07:03 AM | #2 |
Re: nu-rex cut out
I googled the cut out,suppose to come with directions,possibly they can Email you them,you don't want to burn it out.
07-19-2018, 07:12 AM | #3 |
Re: nu-rex cut out
Give Nu-rex a call and as rocket said have them send you the directions. They will tellyou the info but it's always good to save the official directions for the next owner.
07-19-2018, 07:28 AM | #4 |
Re: nu-rex cut out
There are only two connections to the Nu-Rex cut-out, Bat and Gen. The connections would be the same as the one you removed. The yellow/black wire from the terminal box would go to the Bat terminal. The two yellow wires from the switch block provide 6 volts to the switch and the horn. This, of course, assumes the rest of your wiring is correct.
Frank |
07-19-2018, 07:45 AM | #5 |
Re: nu-rex cut out
Is that a F-100 steering box seen in one picture?
07-19-2018, 10:33 AM | #6 |
Re: nu-rex cut out
07-19-2018, 11:45 AM | #7 |
Re: nu-rex cut out
All three wires go to the BAT side of the cut out.
Bob |
