12-07-2019, 12:29 PM | #1 |
oil pump
I have a new rebuilt flathead 8BA that an old timer built for me who has since passed. I had oil pressure when I first ran it and now nothing. Was running it working on it and it made some weird noises so I shut it down. No oil pressure. Can I remove this pump from just removing the oil pan? Thanks, Dave
12-07-2019, 12:52 PM | #2 |
Re: oil pump
From your description, it is likely the engine will have to come out anyway. When oil pressure suddenly drops when the engine is running, bearing damage is likely. In some cases the pipe linking the pickup to the pump comes loose and allows the input to drop. The pipe is press fitted into the pump. We secure the joint by brazing when installing.
12-07-2019, 01:25 PM | #3 |
Re: oil pump
I pulled the inspection cover off and the pickup seems fine and in place. Brand new motor.
12-07-2019, 01:46 PM | #4 |
Re: oil pump
If it's easy to remove the oil pan , go for it , the pump will come out with one more bolt .
If you have to remove front end stuff , just pull the motor . First I would mount a mechanic an gauge and crank the motor , no spark to check for oil pressure. Then I would drain the oil into a clean container and look for metal or silver paint . If any exist, pull motor . |
12-07-2019, 03:04 PM | #5 |
Re: oil pump
I did install a mechanical gauge,nothing. I pulled the cover for the oil pickup access and ran my finger along the bottom of the pan. very gritty,fine pieces of metal as they stick to a magnet. This motor doesn`t have 5 minutes of run time on it.
12-07-2019, 03:09 PM | #6 |
Re: oil pump
12-07-2019, 03:55 PM | #7 |
Re: oil pump
That`s what I was afraid of,what a pain.So close to having this 29 roadster done. Anyone know any flathead mechanics in Minnesota?
12-07-2019, 04:07 PM | #8 |
Re: oil pump
Dave is an excellent flathead builder. I think he is in the Rochester area.
12-07-2019, 05:09 PM | #9 |
Re: oil pump
Flatjack9, Do you have any contact info for Dave?
12-07-2019, 11:34 PM | #10 |
Re: oil pump
12-07-2019, 05:11 PM | #11 |
Re: oil pump
Bored and stroked, I was surprized to find how dirty the oil was after not even five minutes of run time ,if that. The old builder had to miss something,to bad he passed away last year.
12-08-2019, 08:12 AM | #12 |
Re: oil pump
12-07-2019, 04:40 PM | #13 |
Re: oil pump
Given that you've started/ran it multiple times . . . my guess is that the bearings will now be toast - any maybe the crank journals as well. You need to figure out the cause of the issue - can be a range of things:
1) The oil pump could have an issue - something mechanically failed. 2) The pressure relief valve may have stuck open - but usually you'll still see some pressure. 3) The little gear on the back of the cam that drives the pump may have come loose (only has a too-small flat on it to keep the gear from turning). I typically tack-weld the gear onto the end of the cam - and/or roll-pin it. 4) Depending on the crank, I've seen the rod-journal clean-out plugs get blown out . . . causing a major open leak. This is most common on the Merc cranks - as they have big clean-out plugs. I'd start with the oil-pump . . . then see what you can find from there. Good luck! B&S Last edited by Bored&Stroked; 12-08-2019 at 12:30 PM. |
12-08-2019, 08:04 AM | #14 | |
Re: oil pump
12-08-2019, 09:15 AM | #15 |
Re: oil pump
I would start first things first.
Pull the pan,,,,look for a missing clean out plug on the crank. If it blew one out,,it would make an unusual noise as it was bouncing around off the spinning assembly. If that is it,,,maybe it is not too bad. You could start pulling the main caps and checking the bearings. Then the rod caps and so on. Being the engine was running only a few seconds and not under a load,,,maybe it didn’t hurt anything ? If not the crank plug,,,then the oil pump,,,remove it,,,check it for any problems. Then if not there,,,,the drive on the cam is next. And you could still pull the cam without pulling the engine. A lot of work,,,yes,,,but possible. Maybe you will get lucky,,,I hope so. Tommy |
12-08-2019, 09:51 AM | #16 |
Re: oil pump
If it has the magnetic particles that you speak of there is no magic fix left,take it out find the problem and repair it. A picture would help.
R |
12-08-2019, 05:43 PM | #17 |
Re: oil pump
Question do you have the external oil filter conversion on the engine? Reason i ask if the oil lines to the remote filter are installed incorrectly the engine will become toast in short order.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-08-2019, 08:28 PM | #18 |
Re: oil pump
Ronnieroadster,Yes I do have the beehive oil filter. Pressure in on the bottom and out the side. Pressure line in from rear of block right?
12-08-2019, 10:56 PM | #19 | |
Re: oil pump
The feed would be from the rear of the block out of the original oil sender location. Im not sure how the oil line would connect to the housing however if its like the original flathead set up the oil line coming out the bottom of the housing is the oil return to the oil pan only. Since its a beehive i would expect the oil return is only going to the oil pan just draining back into the pan not feeding the engine the oil under pressure. If the beehive is being used to actually feed the engine oil under pressure that may be the cause of the failure first if the oil lines are installed backwards and second the fact the beehive as far as i know is not designed to be the actual oil feed supply for the engine such as feeding oil under pressure to the bearings. Pictures of how the oil lines are connected would help determine how its actually being used. Ronnieroadster
12-08-2019, 07:16 PM | #20 |
Re: oil pump
Sorry to hear .. I feel your pain
"Came too close to dying to stop living now!" |
