Old 07-15-2019, 04:14 PM   #1
wahoo54
Default Stock 1938 Ford Tudor sedan
Will putting 650/16's on the rear and 600/16's on the front look OK on my stock 38 or should I just go ahead and put 600/16's all around? I'd like to give it a little rake but the 650's have a 4" white wall and the 600's a 3". 650's are maybe 3/4" taller.
I don't plan to lower it at this time but who knows. Any input appreciated. It's got the V860 and is stock all around with a flat satin black paint job and stock hub caps.
wahoo54 is offline   Reply With Quote
Old 07-15-2019, 04:17 PM   #2
Darrell S
Darrell S's Avatar
Default Re: Stock 1938 Ford Tudor sedan
The 38 is fine looking car, I think your choice of tires should suit you. I think it would look good. IMHO.
Darrell S is offline   Reply With Quote
Old 07-15-2019, 05:54 PM   #3
tubman
tubman's Avatar
Oh come on! Why don't you go just a bit bigger on the rear? As Carl Kohler used to say, "If some is good, more is better, and too much is just enough".
Old 07-15-2019, 06:01 PM   #4
JSeery
JSeery's Avatar
I have a Tudor, love the look. And big rear, little front is always look good!
Old 07-15-2019, 06:11 PM   #5
ford38v8
ford38v8's Avatar
Your stock rims are 3.5" wide, which takes a 5.5" tire. 6.00" tires will work on this rim, but you would need to up the rim size to 4.0" to go with the 6.50" tires.
Alan
ford38v8 is online now   Reply With Quote
Old 07-15-2019, 10:05 PM   #6
wahoo54
Thanks all!
ford38v8
Thanks for that. Saved me from having to buy new wheels.
Jerry
