Old 09-13-2013, 11:39 AM   #1
Fixmnflym
Default Mystery Fender
Hi. Anyone have any info on these pics? My Dad has decided to clean out his garage. Several fenders have been up in the rafters since back in the 60's, not sure what this is.
Fixmnflym is offline   Reply With Quote
Old 09-13-2013, 11:53 AM   #2
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: Mystery Fender
Fixmnflym ................
Looks like it might be a '35-'36 FORD fender. If it is, it could be pretty valuable. Don't give it away. It looks like it might be NOS. There are some sharks, out here, who will try to get it for nothing.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 09-13-2013, 11:55 AM   #3
Karl Wescott
Karl Wescott's Avatar
Best estimate is a 1938 Standard Sedan. The twist of the mounting flange at the rear is the indicator.
Karl Wescott is offline   Reply With Quote
Old 09-13-2013, 12:15 PM   #4
Chris Nelson
Chris Nelson's Avatar
Karl is probably the best fender identifier there is since he and his dad made fenders for Fords for years.
Chris Nelson is offline   Reply With Quote
Old 09-13-2013, 12:29 PM   #5
37 Coupe
37 Coupe's Avatar
Probably right but I don't think he knows stakebed fenders as on another fender post.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-13-2013, 06:38 PM   #6
Fixmnflym
Thanks for the responses. I am learning and will continue to search for any info I can find. Everyone's help is appreciated. If it would help, I can take any measurements or more pictures at different angles that might help someone narrow it down a bit.
Old 09-13-2013, 07:21 PM   #7
sawzall
sawzall's Avatar
It is not a wagon or stakebed fender for sure
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/
sawzall is offline   Reply With Quote
Old 09-14-2013, 08:57 AM   #8
nospartsman
There is a possibility that this fender could be 1940-1941 Ford Sedan Delivery. The view that I would need to see is from the back as it would be mounted on the vehicle. One feature of a 40-41 Sedan Delivery fender is the bolt on flange has some unique indentions to the Delivery between the mounting bolt holes. These indentions are at a right angle to the long indentions between the holes for the bolts. They look as if you took your index finger and made a depression in the metal at a right angle to the long indentions between bolt holes. They are found at the top arch of the fender. I have only seen these markings on Sedan Delivery 40-41 rear fenders. Or it could be for the 1938 Standard car, which will also physically fit the Convertible Sedan body but would need taillight mounting area.
nospartsman is offline   Reply With Quote
Old 11-29-2020, 10:24 AM   #9
Griffin's 41 ford
Hi, It's a 40-41 ford sedan delivery fender...Do you still have it? Do you want to sell it? I'll buy it from you! Thanks!
Griffin's 41 ford is offline   Reply With Quote
Old 11-29-2020, 03:31 PM   #10
Tony, NY
His last activity on here was 10-03-2013.
Tony, NY is offline   Reply With Quote
Old 11-29-2020, 05:04 PM   #11
Carl
Looks like 1940 Ford sedan delivery.
Carl is offline   Reply With Quote
Old 12-01-2020, 09:11 PM   #12
paul55
I have a NOS '35-37 Panel Delivery rear fender listed if anyone needs one.
paul55 is offline   Reply With Quote
Old 12-01-2020, 09:21 PM   #13
GB SISSON
GB SISSON's Avatar
Let me know if you find a 42-47 tonner right rear fender up in those rafters...
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
