Old 03-05-2022, 05:31 AM   #1
Gilby
Send a message via MSN to Gilby
Default High volume oil pump
My problem is, will a mellings high volume oil pump fit in a 8rt truck oil pan with the rear sump and the big clean- out. Does it have the clearance to the bottom of the oil pan? Ol Ron send me your phone # please. My e - mail is crazybill58@ msn.com. Thanks, bill
Gilby is offline   Reply With Quote
Old 03-05-2022, 06:49 AM   #2
69a
Default Re: High volume oil pump
Yes.
69a is offline   Reply With Quote
Old 03-05-2022, 09:33 AM   #3
Ol' Ron
Ol' Ron's Avatar
I wouldn't use a Hi volume Mellings oil pump on any application!! The "Stock" 8BA pump provides enough presser to cut a crank in half.
Gramps
Old 03-05-2022, 11:08 AM   #4
tubman
tubman's Avatar
I agree with Ron.
Old 03-05-2022, 02:39 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
No real reason to use it . . . the 49-53 8BA pump is more than adequate for any application and it fits the stock oil-pan without mods.
Also, you can buy the necessary pickup from Speedway for the 39-48 pans.
Old 03-05-2022, 03:37 PM   #6
40larry
Beware that the pickup tube is many times not adequately welded to the end flange and results can be very bad when the tube drops off the flange and falls down into the oil pan.
40larry is offline   Reply With Quote
