05-02-2021, 09:32 PM | #1 |
33 Cowl Vent
Got some wet feet on the last run so decided to check things out.
Cowl vent flap was always way below the cowl when closed. Got a new rubber from 3 gen. Rubber a lot thicker. Easy job I thought & then found out I'm not as flexible as I was 30 years ago. to make it worse some bolts were metric, one whitworth and one UNF. Question, 1. Should I build up the channel before installing the rubber ?. 2. Should I glue the rubber ?. 3. Is the edge facing up correct |
05-02-2021, 09:36 PM | #2 | |
Re: 33 Cowl Vent
05-02-2021, 09:53 PM | #3 |
Re: 33 Cowl Vent
In central QLD it can happen anytime
Kpar |
05-03-2021, 12:44 AM | #4 |
Re: 33 Cowl Vent
I have never believed that these reproduction 33-34 cowl vent gaskets were ever made to the correct thickness. You could cut one from thin flat rubber and glue it onto your original repro one to make it a bit thicker so that the vent door sits level when closed with the cowl panel. I would not glue it down in the bottom of the channel because that may prevent any water from reaching the drain hole and tube. I think the edge should face down in the channel so as to allow any water to run under the rubber to the drain hole. The rubber is not supposed to seal into the channel bottom. Regards, Kevin.
05-03-2021, 01:03 AM | #5 |
Re: 33 Cowl Vent
Kpar As well as Kevin s have a good look at your channel pour some water into it with the rubber out the upper channel should catch any that gets past the rubber if it should fill up then any spill over should be cort by the secondary lower channel and feed out the drain tube ,Lower one is often rusted , the Ones I have fitted I glue the flat side to the lid the lower part seams to fit the channel ,not sure if its right
05-03-2021, 01:10 AM | #6 |
Re: 33 Cowl Vent
05-03-2021, 04:37 AM | #7 | |
Re: 33 Cowl Vent
Kpar |
05-03-2021, 05:09 AM | #8 |
Re: 33 Cowl Vent
Kieth , have you got the new rubber, I have just got one and you can have it as its so different to tho one fitted to our 33.
If you are removing the flap give me a call so two of us will do it no drama. I ended up reusing my old rubber. Lawrie |
05-03-2021, 05:51 AM | #9 |
Re: 33 Cowl Vent
Trying to make the Cowl Vent on a 1933 Ford Sedan water tight. |
05-03-2021, 08:30 AM | #10 |
Re: 33 Cowl Vent
The lip, which is a modern addition to improve the seal should be up, not down. There is no drain hole beneath the channel where the rubber is installed; the drain hole is in the inner channel where there is no rubber seal. Notwithstanding, I never glue my seals in place.
The problem with the replacement seals isn't so much that they are too thick, but rather not soft enough for the lid to form a depression and therefore a good seal. You may have to install the seal and place the cover on it (unattached) and place a serious amount of weight on top of it for a week or so to depress it down even with the rest of the cowl top. |
05-03-2021, 03:36 PM | #11 |
Re: 33 Cowl Vent
,my sedan is not Glued but I notice the seal is shrunk doesn't line up when closing ,
05-03-2021, 06:37 PM | #12 | |
Re: 33 Cowl Vent
I got the rubber from 3rd Gen with a ridge. Is this where you got yours ?. Keith |
