Old 03-29-2015, 05:36 PM   #1
PC/SR
Default Removing ER brake actuating lever
Decided to do brakes before touring season gets underway. The right side emergency actuating lever will not slide off the shaft. The bolt is loose, and the lever is loose and rattles around on the shaft and will move to the end of the shaft, but stops dead and will not slip further off the shaft. I wonder if the woodruff key got cocked or something? Any help, tip, tricks advise most welcome. Thanks to all.
PC/SR is offline   Reply With Quote
Old 03-29-2015, 05:39 PM   #2
Bob C
Default Re: Removing ER brake actuating lever
I think you need to take the bolt all the way out to
get the lever off.
Bob
Old 03-29-2015, 05:48 PM   #3
Mitch//pa
the bolt shank fits in a groove on the shaft as bob said remove the bolt
Old 03-29-2015, 06:16 PM   #4
PC/SR
Thanks guys, that did it. Much appreciated.
