10-11-2021, 08:07 AM | #21 |
Re: Isky 1023
10-11-2021, 10:09 AM | #22 | |
Re: Isky 1023
10-11-2021, 10:38 AM | #23 |
Re: Isky 1023
Yeah pictures go a long way to teaching us!
"Learn somethin' almost every day, huh Glenn! Appreciate you posting that!! DD" |
10-11-2021, 02:05 PM | #24 |
Re: Isky 1023
Nice article showing our plain lifters and tools.
TIG welding the oil gear on is definitely NOT recommended. A #4 pin is all that is needed. Here is a pic of the light weight version of the lifters. |
10-11-2021, 02:57 PM | #25 |
Re: Isky 1023
10-12-2021, 04:31 AM | #26 |
Re: Isky 1023
10-12-2021, 04:17 PM | #27 | |
Re: Isky 1023
In comparison testing of cast iron to steel, in a couple of engines, one fairly recently, wear seems to be about the same. I ran a 404 in a 315 ci street engine for 7000 miles once. One drag race event and several autocross events along the way. There was slight wear on the cam and lifters but minimal refacing of both kept them going. |
10-12-2021, 09:07 PM | #28 |
Re: Isky 1023
Curious about the advice to not TIG the gear on and only pin it.
10-12-2021, 10:01 PM | #29 | |
Re: Isky 1023
Welding on cast iron will create hard spots and require grinding to remove the gear next time. It will also screw up the heat treat in the gear and possibly reduce the press on the gear. A pin or set screw is like an axle key on an early Ford rear end, you dont need it but it is cheap insurance. |
