08-10-2017, 04:39 PM | #1 |
3 wire alternator connect
What ohm value resister replaces the indicator light? I don't want to use the light.
Thanks Jim G. |
08-10-2017, 11:36 PM | #2 |
Re: 3 wire alternator connect
The Delco manual calls out a 10 Ohm 6 watt resistor for bench testing without a bulb.
you can also use a 1N5404 diode in line with the wire and have the white band towards the alternator.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 08-11-2017 at 12:14 AM. |
08-11-2017, 02:18 PM | #3 |
Thanks mike! Just what I need!
I appreciate your help.
Safe and happy Model A windshield time! |
08-11-2017, 06:46 PM | #4 |
James G send me an email and will send you the directions to add the diode to the alternator for the three wire setup. [email protected]
08-11-2017, 10:29 PM | #5 | |
08-11-2017, 10:38 PM | #6 |
08-11-2017, 10:45 PM | #7 |
08-11-2017, 10:54 PM | #8 |
With the diode in that direction, it would be for negative grd system. In order for a diode to conduct, positive is on the non-striped side (anode). In this instance, the non-striped (anode) end of the diode goes to ignition. Striped (cathode) goes to alternator. This allows current to flow FROM the ignition TO the alternator. Caution: Reversing just this one diode will not make this a positive ground alternator.
