02-11-2015, 08:43 AM | #21 |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Re: What kind of oil do you use?
It's not discarded, it's is re-used. When some of my lady friends need an oil change, they come running. I have more lady friends needing their oil changed than Jiffy-Lube and............little do their husbands know, they are coming to a "Full-Service" Oil and Lube Service Texaco Station.
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
02-11-2015, 09:40 AM | #22 | |
it helps him get more coupons |
02-11-2015, 09:48 AM | #23 |
Save those Rotella coupons for the new-bees who ask about the best oil for their Model A. Seems years ago when I asked that same question when actually it was just about three months ago. My how times flies. I believe Rotella will add years to Sarah like it has added to my love life....as if I needed more lovin!!!!!!!
02-11-2015, 10:09 AM | #24 |
As long as its full !!..
02-11-2015, 05:10 PM | #25 |
I use the least expensive synthetic oil I can find, and change it once per year. This has been my practice going on 50,000 miles and it works.
Bob Bidonde |
02-11-2015, 05:40 PM | #26 |
FYI. I have used Mobil 1 for many years now along with a full flow oil filter on the valve cover. With the driving that I do annually I typically change the oil filter every year and change the oil every other year. The car is in a warm garage year round and the oil is always clean. Just put a drop of oil from the dip stick on a piece of white paper to see for sure. Also this car had a drip coming from the oil pan gasket before I changed it over to Mobil 1. For some reason the Mobil 1 stopped the leak. I figured it was thin enough, etc. to swell up the gasket. Also I can not say this for sure as fact but I was told that if you ever did drop your coolant on the road and your engine starts to quickly overheat, the Mobil 1 will not burn / degrade in performance until it reaches a higher temp then the normal SAE oils. Just a little additional margin of safety to prevent a costly engine rebuild. Welcome aboard and happy motoring!! |
02-11-2015, 06:54 PM | #27 |
Thank you one and all!
02-11-2015, 08:27 PM | #28 |
Valvolene 20/50 synthetic.
02-11-2015, 08:43 PM | #29 |
First off, welcome to FordBarn!! Inquiring about what type of oil to use is akin to opening a can of oily worms. As you've read already, different people use different oil for different reasons. My advice to you is to stick with the oil that the previous owner used.
FWIW The owner's manual for my 1930 Fordor calls for 40 weight oil. Detergent oils did not exist in 1930. Multi-viscosity oils did not exist in 1930. Model A engines do not run at the same temperatures and were not built with the same tolerances of today's engines.
ODFever 1930 Ford Model A Town Sedan "Alyssa" Last edited by ODFever; 02-11-2015 at 09:09 PM. |
