Old 05-23-2017, 01:39 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Homemade Tools Ammeter Cover Remover
I had to fix a couple ammeters and both the original and repro had super tight covers on them, so I had to make a special tool to get them apart.
Note the repro is aluminum and has no black paint on the brass inside the case. I spent more time fixing this one than it was worth. The face also uses white for the marking, while originals are silver.
I got both the pointers centered, but hope they stay that way after the post office throws them around and drops heavy boxes on top of them.
I used my Sterrett 3" hole saw to cut two circles of 1/8" thick aluminum, then cut the 1 5/8" center hole out on my lathe. I then had to use my Dremel to grind away 5 notches for the 4 tabs and alignment bump in the case. The other plate I used a #20 bit to drill two holes 1" apart, then used a #7 bit and drilled two holes for the 1/4 x 20 eye bolts.
This works much better than a screwdriver and hammer.
Old 05-23-2017, 01:42 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Homemade Tools Ammeter Cover Remover
Very nice Tom. I love homemade tools.
Old 05-24-2017, 11:11 AM   #3
3.6rs
3.6rs's Avatar
Talking Re: Homemade Tools Ammeter Cover Remover
So do I.
3.6rs is offline   Reply With Quote
Old 05-24-2017, 11:58 AM   #4
SeaSlugs
SeaSlugs's Avatar
Very cool! Now if only they would make a quality ammeter we wouldn't have to take them apart new haha. I think its one of those parts that I dont think we would mind paying more for - I sure wouldn't for a meter that fit, was correctly made internally, and somewhat accurate out of the box.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-24-2017, 08:17 PM   #5
henry's 31
As always Tom, great tool. Is your background engineering? I admire your great ideas! Thanks for sharing!
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 05-24-2017, 08:30 PM   #6
1930 coupe
I chuck my ammeters in my lathe 3 jaw chuck, being careful not to get it too tight and make dents. I then use a screwdriver next to the chuck jaws and pry the cover a small amount then go to the next jaw and do the same until the cover comes off. It takes about 30 seconds to remove a cover with no damage to the ammeter or cover.
1930 coupe is offline   Reply With Quote
Old 05-24-2017, 08:43 PM   #7
Tom Wesenberg
Thanks, Wish it was, but no, I've just liked to do machine work and work with electronics and make tools that help get the job done better, quicker, and easier.
Old 05-25-2017, 10:54 AM   #8
henry's 31
You continue to give us great ideas in how to make the job easier. Thanks again!
Henry' s 31
Old 05-26-2017, 12:50 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
Sweet
Old 05-26-2017, 06:22 AM   #10
old31
Very clever Tom.
old31 is offline   Reply With Quote
Old 05-26-2017, 07:20 AM   #11
Jeff/Illinois
Jeff/Illinois's Avatar
Yes, very clever and it worked well too!!
Thanks much. We'll have to start referring to Tom as 'K R Wesenberg' Henry would have had you teaching at the Ford trade school in Dearborn. He would have been impressed and wanted to hang out with you!
