Old 12-18-2018, 02:16 PM   #1
TJMack
Default Hub caps loose
Does anyone have a trick for tightening new hubcaps onto the wheels? I took a punch and hammered each individual tang on the inside of the wheel and they're still loose as goose.
TJMack is offline   Reply With Quote
Old 12-18-2018, 02:35 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Hub caps loose
Give the tabs a bit of silicon caulk.
Old 12-18-2018, 04:28 PM   #3
Jacksonlll
Jacksonlll's Avatar
Get the rubber bands from synyders. Work great.
Old 12-18-2018, 04:30 PM   #4
jak
i'vs put a bead of silicon around them but i've also used the "o" that Bratton's sells
https://www.brattons.com/catalog.html?cat=333
There are different sizes for 28-29 & 30-31
jak is offline   Reply With Quote
Old 12-18-2018, 04:55 PM   #5
TJMack
Thanks for the input, guys. Since I just a couple days ago got a shipment of parts that will hopefully be the last I need for a wile I decided to see if I could find some common rubber bands that would work. Much to my surprise, I did.
The next time I order some parts I'll get the Ford approved version. Don't tell anyone in the mean time.
Old 12-18-2018, 10:30 PM   #6
Brian SATX
Brian SATX's Avatar
They were not original so therefore not Ford approved. You can go to Lowe's and get O rings and they will work.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 12-18-2018, 10:55 PM   #7
whirnot
whirnot's Avatar
I only bend about 1/3 of the tangs. That way if you take them off and break a tang, no big deal. I don't bend them anymore than necessary, sometimes not hammering them really flush exposes minor edges etc. You can even tweak them a little before bending. Mine are nice and snug.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
