Old 01-12-2020, 10:26 AM   #1
russcc
Default Oil pump p/up to pan clearance
Finally getting the pan on the 59L. The oil pump pickup screen looks like it either touches or just barely clears the bottom of the oil pan. How much clearance should there be between the 2 surfaces. Thank you Fordbarners.
Old 01-12-2020, 11:53 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Oil pump p/up to pan clearance
I think 1/4" clearance is good.
Old 01-12-2020, 12:13 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
….unless there's 1/2" of sludge in the bottom of the pan. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-12-2020, 01:12 PM   #4
tubman
tubman's Avatar
Since he is installing the pan, I doubt he forgot to clean it out. With today's oils and the maintenance these cars usually get, I doubt 1/2" of sludge will ever be a problem. I think 1/4" is the usual placement.
Old 01-12-2020, 03:16 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
1/2 is my rule works perfectly ever time.
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is online now   Reply With Quote
Old 01-13-2020, 06:57 AM   #6
russcc
Thank you all for you insight. I looks like it came out somewhere between 3/8" & 1/2".
On another oil pan issue, I swear I read somewhere in one of Vern Tardel's books where to locate the external bolt on oil pan breather, but I can't find that reference point. Anyone recall that. I believe the one I have is an Offy.
Old 01-13-2020, 07:58 AM   #7
Terry,OH
Terry,OH's Avatar
You are correct placement of the vent is somewhere. I too remember seeing it.
Old 01-13-2020, 08:44 AM   #8
russcc
More on oil pans. I checked the 59L pan by putting 4 quarts in it when it was level, and they just filled up the sump.
Old 01-13-2020, 09:03 AM   #9
russcc
Here is what the breather looks like. I saw one mounted on flathead oil pan on a stock car racing forum, but couldn't copy the picture.
Old 01-13-2020, 09:06 AM   #10
JSeery
JSeery's Avatar
Do you have a link to the forum?
Old 01-13-2020, 09:17 AM   #11
Ol' Ron
Ol' Ron's Avatar
That breather should be mounted on the drivers side near the tp ton the pan. On our stock car I extended the pan under the starter about 6" to collect the oil during the corners, with 1/2" clearance . WE also had a form of windage tray welded to the inside of the pan. Can't take credit for this, I copied it from a magazine article.
Old 01-13-2020, 09:33 AM   #12
GOSFAST
GOSFAST's Avatar
Hi Russ, we keep those breathers on the shelf here (photo below).
With respect to you pan, assuming it's not bolted in place yet, I would inspect the gasket between the dipstick adapter and the pan, most times they are no longer any good. We've addressed this issue more recently with a repair kit on all the 8BA's we do now.
With the pan on the bench you should also check the dipstick length for correct reading to the amount of required oil in the system (photo below also)?
Thanks, Gary in N.Y.
P.S. The OEM pan-to-screen clearance seems to be about 1/2" built-in as Ronnie mentioned above, anywhere between 3/8" and the 1/2" number is fine.
GOSFAST is offline   Reply With Quote
Old 01-13-2020, 10:23 AM   #13
outlaw
Gary, do you have a shop phone # to contact you about buying dipstick adapter kit? Thank you. Bill
outlaw is offline   Reply With Quote
Old 01-13-2020, 11:11 AM   #14
Bored&Stroked
Bored&Stroked's Avatar
For those of you thinking about a pan breather . . . because they do look cool now don't they!. I just had to put one on my 34 Ford about 40 years ago - mounted it HIGH as I could on the Driver's side . . . was very happy with how it looked. THEN - I drove the car all around town (was my daily driver).
That nice pan breather did a really nice job of keeping my brake pedals, X-member, transmission, rear and everything behind it REALLY NICELY coated in oil. You will find that putting those types of pan breathers will result in oil mist/spray/leaks no matter what you do with them . . . . you'll soon wish you never put the dang thing on.
I still have that oil pan -- needs to be welded up as it will never have a pan breather on it again as long as I own it. LOL
B&S
Old 01-13-2020, 11:28 AM   #15
flatjack9
flatjack9's Avatar
Nothing like real life experience.
Old 01-13-2020, 06:02 PM   #16
Bored&Stroked
I usually run mine at about 1/4" clearance - but anything up to about 1/2" is just fine.
Old 01-14-2020, 01:24 AM   #17
flatheadmurre
flatheadmurre's Avatar
Lesson learned about breather in oilpan...crank slings up a lot of oil...on side is less of a mess...and adding a piece of sheetmetal as a deflector over it isnīt a bad idee...
That said i have a very nice pan drilled and ready for anyone tempted...lol
Old 01-14-2020, 06:01 AM   #18
Bored&Stroked
Somebody have at it please . . . just so I can relive my youth . . . all over YOUR garage floor! LOL. The good news, oil is a heck of a rust preventative . . .
B&S
Old 01-14-2020, 07:15 AM   #19
Ol' Ron
Ol' Ron's Avatar
Pan breather leaked oil?? The one on our pan didn't, ran for several years, still have the pan.
Old 01-14-2020, 07:44 AM   #20
Tim Ayers
I read it that it more so pushed out oil v. leaked it out.
