09-22-2016, 09:39 PM | #1 |
Front crossmember ID help please
What year is this front crossmember. It came in a trove of parts and I'd like to know. Thanks
09-22-2016, 11:15 PM | #2 |
Re: Front crossmember ID help please
Looks like it is a '34 to me
09-23-2016, 10:21 AM | #3 |
Thats what I was thinking but its been years since I had anything to do with model 40's. Thanks
09-23-2016, 10:27 AM | #4 |
My 34 has a riveted on support in the corners. Looks like a 32 to me, but my 32 was butchered by some dummy before I got it so I can't be sure.
Matt 24:36-41 |
09-23-2016, 10:58 AM | #5 |
Doesn't look 32 so I looked at my 32. Radiator holes are 19"+/- apart. This crossmember the holes are 17 1/4 or so.
09-23-2016, 01:33 PM | #6 |
09-23-2016, 02:00 PM | #7 |
Radiator holes on 32 show to be 19 1/4" apart at c/l.
09-23-2016, 02:07 PM | #8 |
09-23-2016, 02:54 PM | #9 |
Radiator holes are clearly evident in pic #1. They are on top of the crossmember in alignment with spring bolt hole in center. They are in the small platforms on each side of crossmember which provide a flat surface for radiator feet/pads to bolt. 32-4 radiators mount directly over the front spring.
09-23-2016, 03:05 PM | #10 |
Motor mounts are much closer together on a '32.
09-23-2016, 03:19 PM | #11 | |
09-23-2016, 04:06 PM | #12 |
Yeah, thats probably what I am thinking of.
Matt 24:36-41 |
09-23-2016, 07:58 PM | #13 | |
Thank you all. As far as I can tell its a 33-34 with the angle reinforcements/radiator mounts missing Last edited by gearheadbill; 09-23-2016 at 08:07 PM. Reason: additional comments |
09-23-2016, 08:14 PM | #14 |
Not sure it matters than much, but just so it is clear for anyone following this thread the "separate piece riveted on" you are referring to are where the radiator supports connect to the crossmember. The "stay" reference are the holes on the main part of the crossmember where the fender braces or "stays" connect.
09-23-2016, 08:20 PM | #15 |
Yes. Your description seems very clear and well stated.
