Old 10-16-2010, 06:42 PM   #1
54HotRod
54HotRod's Avatar
Send a message via Yahoo to 54HotRod
Default Transmission Problems
I was attempting to replace the gasket on the transmission pan and change the filter inside last night when one of the bolts wouldn't tighten down when trying to bolt the new filter on. I checked the other bolts in that hole and they wouldn't catch anything either. There were definitely metal flakes that come out when I pulled on of the bolts out and now I'm confused on what the proper method is to repair this problem, can someone give me insight on what to do?
54HotRod is offline   Reply With Quote
Old 10-16-2010, 07:02 PM   #2
paul2748
paul2748's Avatar
Default Re: Transmission Problems
Sounds like you need a thread repair kit - Helicoil is one brand.
Old 10-16-2010, 07:02 PM   #3
ford1
a couple of things you can do, heli coil it or drill and tap to the next sized bolt
ford1 is offline   Reply With Quote
Old 10-16-2010, 07:41 PM   #4
54HotRod
54HotRod's Avatar
I don't know how to do either one of those, is there a sight that I can go to and learn what I need to do?
Old 10-16-2010, 10:08 PM   #5
54HotRod
54HotRod's Avatar
Nevermind I found a video on Youtube that showed exactly how to do the job.
Old 10-17-2010, 09:59 AM   #6
Ole Don
Ole Don's Avatar
Those are very small bolts, and it sounds like they go in to aluminum. Buy or rent an inch pound torque wrench to put it together. Keep it clean.
Ole Don is offline   Reply With Quote
Old 10-17-2010, 04:39 PM   #7
54HotRod
54HotRod's Avatar
I've got the inch and foot lbs torque wrenches but we didn't even get a chance to use them since we were hand threading them in when this bolt hole was found to be stripped.
Old 10-17-2010, 06:36 PM   #8
Ole Don
Ole Don's Avatar
It looks like the last guy to do the job was to strong. Or maybe a clutz.
Old 10-17-2010, 07:41 PM   #9
parklane
parklane's Avatar
Probably both.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 10-20-2010, 07:47 AM   #10
Rem/Mo
Rem/Mo's Avatar
Some trans pan bolt holes go clear through the pan rail.
If so you can use a longer bolt and put a nut on the top.
Rem/Mo is offline   Reply With Quote
Old 10-20-2010, 08:51 PM   #11
parklane
parklane's Avatar
The hole that is stripped is for the filter, not the pan.
