Old 05-12-2010, 12:59 PM   #1
KIRK!
KIRK!'s Avatar
Default TECH HELP: '53 3-Speed Overdrive Trans in a '40 Tudor????
Will the later ('53) overdrive 3-speed bolt up to the earlier motor('40)? If so how much modification is need in the mounting department?
If all of that is good, how do those trannys work? Are they manually or electrically actuated?
Thanks!
KIRK! is offline   Reply With Quote
Old 05-12-2010, 05:06 PM   #2
Grandadeo
Grandadeo's Avatar
Default Re: TECH HELP: '53 3-Speed Overdrive Trans in a '40 Tudor????
Kirk, I've been asking question about the T-86 3 speed overdrive transmission on this thread
https://www.fordbarn.com/forum/showthread.php?t=304
and have been getting some info from the guys.
Lee
Salt Is Good... Mk 9:50
Grandadeo is offline   Reply With Quote
Old 05-12-2010, 05:45 PM   #3
uncle max
uncle max's Avatar
Not worth the grief, in my opinion. Send Mitchell a 2Tune and get a decent inline OD...
uncle max is offline   Reply With Quote
Old 05-12-2010, 05:49 PM   #4
KIRK!
KIRK!'s Avatar
Huh? Is that code?
Who's Mitchell? What's a 2Tune? And do you mean like a Gear Vendors-style setup?
Old 05-12-2010, 06:09 PM   #5
uncle max
uncle max's Avatar
Originally Posted by KIRK! View Post
Huh? Is that code?
Mitchell Overdrive in NorCal; Healdsburg? (Google & ask for Sue Mitchell)...
A 2Tune is Brit for 2 Grand.
Mine is the 36%, lever operated style. Brings out my inner Enzo, quite like driving a six speed - think 75 mph in 2nd gear. Always that "just right" gear for cornering & passing, plus I can now actually leave town in the '37...
Old 05-12-2010, 06:17 PM   #6
JRjunky
Not worth the trouble, silly putty gears, 6 volt relays that don't work, oil leaks, hard to make mounts, overdrive needs all kinds of connections mechanical and electrical to work proper, get a T5.
JRjunky is offline   Reply With Quote
Old 05-12-2010, 06:30 PM   #7
uncle max
uncle max's Avatar
Here's a shot of the shifter, including the homemade cover, cobbled from one of the wife's meatloaf pans...
Old 05-12-2010, 07:01 PM   #8
41PICUP
41PICUP's Avatar
Check out the article in the new Street Rodder about this subject.
41PICUP is offline   Reply With Quote
Old 05-12-2010, 07:07 PM   #9
41PICUP
41PICUP's Avatar
Easy swap, take out the old torque tube and replace with the Mitchell. 4 hour job, either 26 or 36 % overdrive. Just put one in my 41, running SBC and early running gear, makes for a fun ride.
