01-14-2018, 07:26 PM | #1 |
Valve Adjustment
I installed new valves and ran adjusters all the way down. I have at least .050 clearance except 2 valves that I had to grind stems.Adjusted all to .015. Couple valves only have max .025 left on adjusters before they bottom out.Should I grind those stems to allow more adjust room or am I ok?
01-14-2018, 07:27 PM | #2 |
Re: Valve Adjustment
That's .010 more left.
01-14-2018, 07:41 PM | #3 |
If they ever need to be adjusted more than the .010" there is something wrong.
01-14-2018, 08:00 PM | #4 |
Something is not right here, if I am interpreting your post correctly. May I ask what set of instructions you are following for setting your valves, and if you are using modern valves and/or a modified cam?
01-14-2018, 08:19 PM | #5 |
All my old valves had the stems cut down. Before doing valve job, I adjusted Al lifters down to bottom. Ground 3 angle seats and installed new valves and lapped in. I use the plus 9 method for valve adjust. Clearance before adjusting valves as noted. After adjusting all valves to.015 a couple lifters only have .010 left before they bottom out. The stems I ground allowed for. 050 extra for further adjustment if needed. Usually clearance gets larger with wear. Just wandered if I should give the2 valves a stem grind or let go.
01-14-2018, 08:59 PM | #6 | |
On overhead valves, clearances can get larger with wear: pushrod tips, rocker arm faces and pivot points all wear. |
01-15-2018, 02:26 PM | #7 | |
01-14-2018, 09:02 PM | #8 | |
01-14-2018, 08:25 PM | #9 |
Using original style valves,new split guides and springs
01-14-2018, 08:25 PM | #10 |
I've adjusted mine to .012 intakes and .014 exhaust
01-15-2018, 12:17 PM | #11 |
I have set mine on sixteen thousants , Intake and exhaust . More time on the seat better cools the valves and reduces the chance of burning valves. Snyders recommended this setting , years ago and it has worked good for me . My reground Winfield super street 3/4 race cams use the same sixteen thousants gap .
01-15-2018, 01:09 PM | #12 |
I used the 13 and 15 that is in the Les Andrews book
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
