Old 06-23-2017, 08:02 PM   #21
updraught
updraught's Avatar
Default Re: inspection nightmare
On the right hand side of the country, alcohol must be more useful for other things.
updraught is offline   Reply With Quote
Old 06-23-2017, 08:44 PM   #22
H. L. Chauvin
Adding about 2.5 ounces of regular crankcase oil to 10 gallons of Model A gasoline will work just great for helping to prevent E-10 vapor lock whether MMO is available or not available.
Our old square tank 1930's- 1950's outboard motors "all" used regular crankcase oil before today's 50:1 two-cycle oil which was much later invented and recommended for 2 cycle engines.
H. L. Chauvin is offline   Reply With Quote
Old 06-24-2017, 06:57 AM   #23
Jim/GA
Jim/GA's Avatar
Originally Posted by Tom Wesenberg View Post
I can only guess the percent of corn crap varies between states.
Also consider the age of the fuel, air temp, humidity, engine condition, radiator condition, etc.
Yes, this is true. The amount of alcohol blended into the fuel can vary quite a bit from station to station and even from week to week.
The pumps say "up to 10%". That is true. It won't be over that, but it can be well under that.
Under hood temperature is the wildcard. Some cars run hotter than others. Sit at a light idling and everything under there (carb and fuel) can get quite hot.
In these conditions, I have to open my GAV and start out from the light staying in 1st gear, holding the RPMs up until the outside air cools everything off under the hood. You can feel the power kick in and the engine start to run right again when the carb is cooled off. Then I close the GAV back to normal running position and shift to 2nd.
If I don't do the above, the engine stalls leaving the light.
Jim Cannon
"Have a Model A day!"
Old 06-24-2017, 06:58 AM   #24
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: Boiling Gasoline...
Originally Posted by jb-ob View Post
Barry B,
Common hot weather problem with a Model A. After a drive the fuel in the hot carburetor boils the gas and the fumes 'flood' the engine. Hard to re-start, runs poorly until the excess gas is drawn off.
First check to see if your carburetor has a vented fuel bowl .... re-designed after mid 1929., which allows some of the excess fumes to escape.
On a hot day drive, shut off the fuel valve allowing the engine to run until the carb is dry. Later turning on the gas valve allows 'cool' gas from the tank to fill the carb. Works for me.
I suspect that adding of MMO or diesel to the gasoline lowers the volatility making it harder to boil off & flooding the engine.
Hope some of this is helpful, JB
Thanks jb, I just turned off the ignition in the inspection bay and tried to start it after a few minutesso I assume the gas boiled from the heat, very embarrasing, all kinds of popping and no throttle response, it was hard to tell if it was a condenser or fuel flow. Thanks for the advice, I'll keep the Mystery oil handy and let it run dry when hot. Barry B.
Barry B./ Ma. is offline   Reply With Quote
Old 06-24-2017, 07:25 AM   #25
barkleydave
barkleydave's Avatar
I run real gas and still have the problem stopping for a fuel stop on a tour on a hot day. I use MMO and it helps some. I found if on a hot day on tour I fuel... open hood and poor cool water on the fuel bowl (Not Ice Cold) and no issue. About a half bottle seems to do the trick. I would be afraid to poor ice cold water it might crack the fuel bowl. Also just letting it idle for about a minute or so will cool it down but seems like on tours folks want to roll right away.
barkleydave is offline   Reply With Quote
Old 06-24-2017, 07:46 AM   #26
Kevin in NJ
So I have always railed against the 'vapor lock' on the A.
As such I have enjoyed some people relating stories as to why they do not believe either in PM's.
So on person related to how they had the typical engine 'vapor lock' problem for a few years. He tried all the fixes and none worked really.
Then he had to take the engine apart for other reasons and he noticed the valve gaps were done wrong and uneven. So he redid the valve properly. When he put the engine together no more vapor lock.
To approach this logically you have to think well only some cars ever have a problem. So on a tour a couple of cars are having a problem and they are all in the same conditions with the same gas. Right there tells me it is a build problem.
What goes wrong, well that is the problem. What is more likely wrong is a bunch of little things. Timing off a tad, valves slightly off, maybe the water jacket is not cleaned out as well as it should be and they all add up- sometimes- to cause a problem.
How many people are aware the valves need to have the gap set for how the metal expands. You can not just go by what the service bulletins say. You have to know the expansion rate of the metal.
Doing the A engine right is not simple. People do not realize the A engine is a high precision built device. They poo poo that thought and think it is just an old engine why bother with accuracy. You really have to think your are building a race car engine as you approach the constuction of the engine.
The A engine runs great if it is done right. You should not have to do any modern fixes to get it to be extremely reliable (well the burn out proof condenser is essential, no not the V8 one).
Old 06-24-2017, 08:25 AM   #27
John_Carter
John_Carter's Avatar
I was definitely in the camp that said if you have fuel problems, there must be something wrong with your car because it doesn't happen to me. Until... going up Mt. Mitchell off of the Blue Ridge Parkway. I also had similar problems in Mississippi after hours of sustained 50mph driving. At one point I noticed rolling bubbles in the sediment bulb. It was hard to take a good picture of that, but I did get a picture of the giant bubble that formed as the moving bubbles stopped. I had a couple days with similar conditions and with multiple fill-ups per day I know it wasn't just one particular tank of gas. Higher octane gas didn't seem to help. It pains me to say it, but after adding MMO the problem went away over the next couple of days and 1000+ miles.
More information on the trip here: http://www.sheepisland.com/3000modela/
John_Carter is offline   Reply With Quote
Old 06-24-2017, 08:30 AM   #28
Boston Bruce
Boston Bruce's Avatar
Originally Posted by Barry B./ Ma. View Post
Thanks jb, I just turned off the ignition in the inspection bay...
Barry,
Next time just don't get the car inspected. What is it now $39 for essentially nothing.
Boston Bruce
Boston Bruce is offline   Reply With Quote
Old 06-24-2017, 09:07 AM   #29
jb-ob
Barry B.
It might just be Inspection Stations. I too have suffered a dented ego at the same locations.
I have long believed the remaining Model A's are here to keep us humble. First sign of a puffed up ego, they have a knack of embarrassing at the perfect spot, ie. Inspection Stations, entrance to the Hershey Show Car field on Saturday etc.
John Carter; Great site about your tour through National Parks.
I'm satisfied if I make it to the next town & back. Wife no longer wants to ride as she is tired of driving back with strange men in the front of a flat bed truck.
Yup, it's tough...... JB
jb-ob is offline   Reply With Quote
Old 06-24-2017, 09:23 AM   #30
Beater
Beater's Avatar
I'm not sure I believe this. speaking from experience in a small 2 cycle engine that got regular 10-30 motor oil instead of 2 cycle oil it fouled the plug in no time to the point that the engine wouldn't run. pull plug clean plug, foul again in short order. regular crankcase oil is not designed to burn , and doesn't burn clean or completely.
the same as adding ATF to your fuel, its not really designed to burn clean. you are much much better off adding MMO or a good brand 2 cycle oil to your fuel for good upper cyl lubeing
Beater is offline   Reply With Quote
Old 06-24-2017, 09:15 PM   #31
Ed
If you decide to use ATF, avoid the types that have silicone in them.
Ed is offline   Reply With Quote
Old 06-24-2017, 09:21 PM   #32
Joe K
Joe K's Avatar
Wooden clothes pins on the gas line.
Some put tinfoil between the clothes pins and the tube.
Don't ask me why it works.
Joe K
Shudda kept the horse.
Old 06-25-2017, 08:46 AM   #33
GPierce
GPierce's Avatar
Joe K
Wood makes a pretty good insulator.
GPierce is offline   Reply With Quote
Old 06-25-2017, 10:02 AM   #34
JDupuis
JDupuis's Avatar
John_Carter, loved your blog of your long distance tour. Would love to do a tour like that myself. Thanks for sharing. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 06-25-2017, 11:33 AM   #35
Mikeinnj
Mikeinnj's Avatar
Originally Posted by Dick Steinkamp View Post
Here are the gas stations that sell ethanol free gas in the US...
https://www.pure-gas.org/index.jsp?
With the exception of a few states, ethanol free gas is relatively close to everyone.
If you feel that e10 is causing your problems, you might want to fill up with a few tanks of ethanol free gas to test that theory.
Checked the prices for unleaded gas on the websites listed in the north-east and the price for a gallon of 94 octane unleaded gas ranged from $10.00 to $30.00 a gallon. All the Model A's I have owned run on 89 octane ethanol with no snake oil or other additives. I believe poor running cars have poorly tuned engines.
Mikeinnj is offline   Reply With Quote
Old 06-25-2017, 01:05 PM   #36
Beater
Beater's Avatar
well for me the reason to add some MMO or 2 cycle oil is for some top end lube as the new oils have no zink and other good stuff in them. to ea his own however
Old 06-25-2017, 11:58 PM   #37
Tom Wesenberg
Tom Wesenberg's Avatar
Today's gas is not like the good gas of the 60's and 70's, never mind the lead. It boils too quickly and is what I call a drier gas, as it doesn't lubricate at all compared to the older gas. That's why I like a bit of oil mixed in.
If someone wants to think my gas boils because I haven't properly tuned my car, well, they can think what ever they please.
Old 06-26-2017, 06:37 AM   #38
WHN
Very well said. I have always used MMO in the gas. So far has kept us from having this problem.
Old 06-26-2017, 09:17 AM   #39
Beater
Beater's Avatar
very true things definatly seem dryer, and a bit of 2 cycle oil makes my valves and upper cyl much much happyer
