07-16-2011, 01:08 PM | #1 |
Spring Clamp
any thoughts on the originality of these spring clamps? May be a "T" item but fits "A" spring (front and rear) nicely. Early "A"?
07-16-2011, 04:04 PM | #2 |
Re: Spring Clamp
Charles,
Both sets of my Ford script springs don't have them. In the photo the nut(I think) is incorrect. What does the " dimple " on the top of the clamp look like? Dudley |
07-16-2011, 05:54 PM | #3 |
Re: Spring Clamp
my spring leaves are also script (didn't think to take photos while i had them apart) .. don't recall where i got these clamps ... i suspect they are repros but i dont see them in any of the A/T vendor sites.
i have one set of correct bolts/nuts but need another as well as needing 4 correct clamps (some had small script on top ... not seen) |
07-16-2011, 05:58 PM | #4 |
Re: Spring Clamp
Charles, those look like repops. Easy way to tell. If original script clamps the dimple on top will be round. The repops have a tab. Rod
07-16-2011, 06:09 PM | #5 |
Re: Spring Clamp
That's what I'm thinking.
07-16-2011, 06:31 PM | #6 |
Re: Spring Clamp
I got a real nice front spring with minimal wear and they were clearly later production and Ford script just like the ones you have. I switched them with some production clamps. The spring shackles are another example of the Ford script on later parts. For a long time people thought that one type of Ford script shackles were late production. A couple of years ago drawings were found that proved they were after A production. |
07-16-2011, 07:24 PM | #7 |
Re: Spring Clamp
The spring clamps on my late 31 sport coupe were rivited, not bolted. I assumed they were factory originals. I rebuilt the springs with bolts and nuts in the clamps. It's going to be a driver.
07-16-2011, 08:35 PM | #8 |
Re: Spring Clamp
Charles, I forgot I still had these around, but here are the repops. Rod
