07-14-2011, 12:51 AM | #1 |
Engine storage
Advice please,
I've just finished putting together my B engine but for now, I have no way to test run it. All the parts have been assembly lubed and no oil in the pan. I would rather not install it in the car and then find out I need to do some more work on it. What would be best way to store my project for probably the next 6 to 8 months? I will be a garage, nice and dry. Thanks, Pete |
07-14-2011, 01:17 AM | #2 |
Re: Engine storage
I would just tape up the openings to keep critters out, and store it in the driest place you can find.
07-14-2011, 05:04 AM | #3 |
Re: Engine storage
You might want to put a reminder on the calnder to
TURN the engin over by crank once or twice a month!! Just a thought |
07-14-2011, 05:43 AM | #4 |
Re: Engine storage
Tom's right about taping up any and all openings. mice love to go into any little hole they can find.
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts https://www.fordbarn.com/forum/group.php?groupid=5 |
07-14-2011, 08:28 AM | #5 |
Re: Engine storage
Thanks guys. I was thinking of trying to "fog" the insides with oil but I'm probably over-thinking the situation as usual. I assume agreement in test running if possible prior to installation?
07-14-2011, 10:05 AM | #6 |
Re: Engine storage
07-14-2011, 10:33 AM | #7 |
Re: Engine storage
You've got a point about having a load on it to seat rings etc. I guess I'm just anxious to run it. As I mentioned, this winter I'll probably want to drop it in anyway whether or not I test it beforehand.
07-15-2011, 12:26 AM | #8 |
Re: Engine storage
What is the consensus on engine pre lube used by builders vs a conventional grease to lube the engine with durring assembly? Mine will set for a year or so before I can fire it up so I will rely on the lube applied durring assembly while the oil works through the system.
07-15-2011, 03:00 AM | #9 |
Re: Engine storage
The assembly lube needs to be light enough to let the oil flow through the openings to lube the engine as soon as it starts. The assembly lube also need to NOT thicken or dry during your storage period. I would think something like Mystik JT6 High Temp grease would will these needs. I've seen other grease that drys up during storage, and I have some old tubes of grease that I know is too thick to use.
07-15-2011, 10:22 AM | #10 |
Re: Engine storage
Tom, what I did was to smear it on the moving/sliding surfaces just enough to give them a complete coating. Hopefully this and turning it over from time to time will keep it limbered up. If I had a way to connect it to a muffler I'd fire it up in my garage.
Pete |
