Old 05-21-2013, 10:50 PM   #1
REByar
Default Is there Difference between Champion 3X Spark plugs
Hi All
IS there a difference between the Champion 3X plugs sold by Snyders, Macs, Brattons and the 3X plugs sold by O'Reilys (Champion part #429) ?
Any thoughts would be greatly appreciated.
Thanks
REB
REByar is offline   Reply With Quote
Old 05-21-2013, 11:32 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Is there Difference between Champion 3X Spark plugs
I don't think so, as there is only the modern repro 3X being sold now.
It's too bad the thick hex for 28-9 isn't being made.
The 3 now has a flat top, and the knurling is also wrong.
Old 05-22-2013, 12:06 AM   #3
700rpm
700rpm's Avatar
Can anyone post a picture of the different types of 3's, including the original and current versions?
Ray Horton, Portland, OR
Old 05-22-2013, 04:16 AM   #4
30ccpickup
30ccpickup's Avatar
700rpm here are some drawings of the differences, I will try to post some actual photos later today. http://modelabasics.com/3xplug.htm
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 05-22-2013, 07:31 AM   #5
Tom Wesenberg
The diamond knurling pattern stands OUT on original plugs and they go IN on the repro 3X, plus the knurling doesn't run all the way down on the modern 3X.
Old 05-22-2013, 10:53 AM   #6
700rpm
700rpm's Avatar
Thank you!
Old 05-22-2013, 12:39 PM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
It's a real shame that they went through so much to duplicate the plug and missed on a few details.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 05-22-2013, 06:06 PM   #8
700rpm
700rpm's Avatar
MIKE
It's always like that, isn't it? But still, they look pretty neat in the car.
Old 05-22-2013, 06:36 PM   #9
30ccpickup
30ccpickup's Avatar
