Old 09-20-2016, 12:29 PM   #1
GComo
GComo's Avatar
Default Travel Speed
I have a "high speed" AA that I enjoy driving around town. I realize this is not a fast truck. And have no desire to make it a fast truck. My question is what is a reasonable speed to drive without hurting the motor? I usually travel around 35-38 mph and have been told this is too fast.
Thanks
GComo
GComo is offline   Reply With Quote
Old 09-20-2016, 12:32 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Travel Speed
as long as you have the high speed rearend gearset 35-40mph is perfect. If you have the low speed 20-25...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-20-2016, 12:52 PM   #3
GComo
GComo's Avatar
Thanks for the reply. That's what I thought.
Old 09-20-2016, 12:59 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I like to keep engine speed below 2,000 RPM for cruising. Sometimes you have to go a bit faster, but about 2,300 is what I would think of as red line.
Old 09-20-2016, 01:05 PM   #5
GComo
GComo's Avatar
What would that translate to in mph?
Old 09-20-2016, 01:33 PM   #6
1crosscut
1crosscut's Avatar
A very comfortable cruising speed for my worm drive AA is 28 mph. I can go faster but the rpm's start to climb pretty quickly past that point. The later trucks with the bevel drive rear ends can do a bit higher speed I understand. Is yours a worm or bevel gear rear end?
Low speed worm drives will get you 10 - 15 mph.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 09-20-2016, 01:36 PM   #7
GComo
GComo's Avatar
I have an early 1930 with bevel gears.
Old 09-20-2016, 01:42 PM   #8
apbright
apbright's Avatar
My math says, with a stock 3.76 rear-end ratio, rpm = 41.2*mph. Thus 40mph = 1650 rpm.
I'm guess all AA-trucks have 4.11 rear-end ratios, changing the formula to rpm = 45*mph. That would make 40 mph give 1800 rpm.
apbright is offline   Reply With Quote
Old 09-20-2016, 01:48 PM   #9
GComo
GComo's Avatar
It has 5.14 gears. Not sure how to do the math.
Old 09-20-2016, 01:49 PM   #10
SeaSlugs
SeaSlugs's Avatar
worm drive AA's are 5.14:1 high speed or 7.25:1 low speed
30/31 bevels were 5.14 high speed and 6.6 low speed
same 600x20 tires. (32" diameter)
http://www.crawlpedia.com/rpm_gear_calculator.htm
so according to that the 5.14 ratio:
30 mph is 1619rpm
35 mph is 1889
40 mph is 2159
45 your over redline at 2429rpm
for S&G heres low speed 6.6 bevel:
15 mph is 1040
20 mph is 1386
25 mph is 1733
30 mph is 2079
35 is above redline at 2426rpm
Old 09-20-2016, 02:10 PM   #11
GComo
GComo's Avatar
Thanks that helps a lot.
Old 09-21-2016, 01:49 PM   #12
Big Iron
I have an early 30 with a high speed worm. It likes to run at 32 to 38 mph. You can tell what it likes by the sound. I run it up to about 40 quite I bit but only when I have to. It will do 47 or so but that is pushing it to hard.
Big Iron is offline   Reply With Quote
Old 09-22-2016, 06:24 PM   #13
GComo
GComo's Avatar
Thanks. I've only run it up to 40 to get a run on steep hills.
