Old 01-22-2020, 04:40 PM   #1
David J
David J's Avatar
Default Where to get a windshield frame seal for a 34 Phaeton
Any ideas on getting a couple windshield frame gaskets-seals for 33-34 phaeton-roadster .
Original stepped frames .
Drake says obsolete and no stock left .
Thanks
David J is offline   Reply With Quote
Old 01-22-2020, 05:02 PM   #2
TJ
TJ's Avatar
Default Re: Where to get a windshield frame seal for a 34 Phaeton
Check with other V-8 parts vendors. I'd start with Third Gen Automotive, Michael Driskell. Some vendor may have it on the shelf.
Old 01-23-2020, 05:09 AM   #3
deuce lover
deuce lover's Avatar
Early Ford V8 Sales in SC has them $10.Listed a 1930 to '36 ."T" rubber style.Good people to deal with!!
https://www.parts123.com/parts123/dy...=0000019a02683
deuce lover is offline   Reply With Quote
Old 01-23-2020, 01:49 PM   #4
DavidG
DavidG's Avatar
I doubt that the weatherstrip from SC will not work in an original '33-'36 phaeton/roadster windshield frame unless what they actually sell differs materially from their photos. The amount of rubber at the junction of the horizontal and vertical portions forming the "T" is well in excess of the original and simply will not fit into the channel of an original frame. I have a bunch of like it in my scrap pile.
Old 01-23-2020, 01:52 PM   #5
35fordtn
35fordtn's Avatar
David J,
Call Joe's antique auto... I think you'd be surprised at the amount of stuff he carries. As of this morning he had a drake one on the shelf
35fordtn is offline   Reply With Quote
Old 01-23-2020, 02:19 PM   #6
David J
David J's Avatar
Talking Re: Where to get a windshield frame seal for a 34 Phaeton
Thanks Michael ,
It's on it's way .
Thanks to all for trying to help !!!
Originally Posted by 35fordtn View Post
David J,
Old 01-24-2020, 08:01 AM   #7
JMFL36
JMFL36's Avatar
Another '34 Phaeton owner. Yay! Do you have side curtains for your car?
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 01-24-2020, 09:34 AM   #8
David J
David J's Avatar
Yessir ,
This is Mike Burches old car .
I am the new caretaker .
Old 02-21-2020, 03:53 PM   #9
David J
David J's Avatar
Found out some stuff on this subject .
The discontinued Drake WS seal does NOT fit original frames .
Only the repo square ones .
It is 2 pieces and looks like the T-Strip Sheldon references .
Good news is the sedan one sold by Carpenter does indeed fit .
You need to cut it off at the pivot bolt and use a short piece above the pivot bolt .
It seals all the way around if in fully retracted position .
Cheap to boot .
