11-15-2014, 04:53 AM | #21 |
Re: fuel consumption idleing?
So... anyone care to answer the original question" What's the fuel consumption when idling?"
11-15-2014, 04:59 AM | #22 |
There is no answer as the poster never told us what kind of car.
11-15-2014, 06:07 AM | #23 |
I would use a tygon hose and a quart jar of gas, then run the engine until you use up 1/2 quart of gas, then multiply the minutes times 8 and you'll know how long it will run on a gallon of gas. This would be good to know if you had to run the engine for heat while stuck in a snowbank. I got stuck in a blizzard in South Dakota with my Corvair, but after 30 minutes I had to walk a half mile to my uncle's farm house because the Corvair heat was poor when the temp was below about 10 degrees. After that my hands freeze up very quickly when I go outside in the winter, even with gloves on.
A Model A with a manifold or hot water heater would have provided much better heat. |
11-15-2014, 06:34 AM | #24 | |
There really is not a good answer to your question. It depends on a lot of things. How fast the ideal, where the spark is set, how you have the carb set, what kind of shape your engine is in,If you have the 10 percent crap gas, the list goes on. |
11-15-2014, 08:53 AM | #25 |
Do we know the make of car involved ? I think not. It sounds like it may well not be a Model A Ford. Could FrankWest please clarify this issue first. .
Wayne |
11-15-2014, 10:04 AM | #26 |
Paul in CT |
11-15-2014, 01:02 PM | #27 |
Would a no reply be more productive than bashing Kind of like play ground
bulling I don't mean to be an ass IMO |
11-15-2014, 04:46 PM | #28 |
I think it is a interesting question,what amount of fuel does a model A burn at an idle for a given time,of course it would depend on the idle speed and carb settings,type of fuel etc.
11-15-2014, 04:53 PM | #29 |
11-15-2014, 11:35 PM | #30 |
Some people do it to gather more information to give a better answer, some just to be an ass.
11-16-2014, 07:47 AM | #31 |
Well!
11-16-2014, 08:59 AM | #32 | |
Did you attend PS 116 in Queens in 1961? Yout sound just like the kid that bullied me back then. I will not post again....., I will not use this forum Excuseme for just being excited about my car...I should have known better an kept my excitement to myself. |
11-16-2014, 01:20 PM | #33 |
Good on yer Frank - illegitimi non carborundum- (don't let the bastards grind you down) From a very rough calculation I reckon a Ford A idles at about 6 litres per hour. ( er that's about 1.3 imperial galls per hour, er er 1.6 US galls)
11-16-2014, 01:30 PM | #34 |
Hi Frank,
FWIW: In my humble opinion, your very simple, honest & straightforward question was no different than so many simple, basic questions ever asked on "any" vehicle Forum; like maybe: 1. Have coolant on floor, so where is my coolant leak? Why does my front tire leak? 2. Have oil on floor, so where is my oil leak? Gas, so where is my gas leak? 3. Why my car won't start? How many mpg should I expect with W18 plugs? The "exact", correct answers, even though most embarrassing to the "Model A Know-It-Alls" are: Nobody on "any" Forum really knows the "exact", specific answers to such "general" questions. So, in some cases, some reply with wild guesses; 79.46% ask you to check your condenser, (even if the problem is that the front tire is low); in good faith, some ask a few questions for more details; & some may try to make a joke out of the question; but such is life. Again, in my opinion, your reply #32 should be a reminder for "all" of us that we "may" have accountants, lawyers, doctors, etc., who just obtained a vintage car. Then this person, (very much "uninformed" about vintage vehicles, but skilled in another area), just asked a simple question. If you re-review your above replies, it appears many were really trying to help. We all have seen replies like your reply #32. It should be respected, & it hits home for those who care. I like your car, & I think if you have any questions, you should just jump back in & tell somebody else to check his coil when his transmission is leaking. Such is life. |
11-16-2014, 11:19 PM | #35 | |
Wayne |
11-17-2014, 12:31 AM | #36 |
I can drive my Model A at 2000 RPM pushing the car down the road, and burn 2 gallons of gas per hour, so I would think the engine idleing at 500 RPM and not pushing a load would burn less than half a gallon per hour.
11-17-2014, 08:12 AM | #37 |
Yes, you're right Tom , thanks. I think your figure using common sense is probably much nearer than my figure which i extrapolated from how long the engine idles after switching off the fuel tap!
11-17-2014, 01:39 PM | #38 |
Hi Wayne,
Thanks for your very intelligent & compassionate reply #35. I sincerely hope Mr. Frank reads it & can assure him enough peace of mind to jump back on this Forum with both feet. Furthermore, anyone ever notice what happens when someone reports on a Forum that he has a very parochial question which he announces as a "Stupid" question. Next, "everybody" gets up on his soap box to preach: "There is no such thing as a "stupid" question." Then another very kind & considerate person asks a very legitimate & honest question where nobody really understands why this question was asked .......... so back on the soap box where some appear to preach -- What a "Stupid" question. |
11-17-2014, 04:23 PM | #39 |
I have wanted to leave this forum at times too, due to personal attacks against me.
However, I have found that after awhile, I just skip the note if it's from the usual "insulting people". I learned many years ago, that some people "hide" behind a keyboard and couldn't make it in a face to face meeting saying the type of crap that they use in the forum. There are many good people here, but, there are also some real jerks... Marc |
11-17-2014, 05:00 PM | #40 |
Well said and right to the point Marc. And I totally agree with you.
