03-17-2011, 02:17 PM | #41 |
Re: Installing dual 94 carbs on a Model A ratrod
To clarify: The PV's open when vac drops below their set point, but the fuel available through them feeds into the same passage that delivers fuel from the main jets into the venturis. The venturis do not have enouh pressure drop to pull gas from main and PV circuits until a substantial amount of air is moving though.
The holes you see in your PV serve only to ley gas flow when the openings are fed by the valve...the actual metering of the gas (controlling the amount that can flow via the PV) is controlled by restrictions in the passage in the body casting that lead gas away from the valve. In effect, the gas delivery can be thought of as 2 small extra main jets opening up...any gas actually moving has to be pulled though by the pressur drop generated by venturi flow. In any discussion of rh Ford 94's, there are people who seem to blame low speed problems on th PV when it is actually flowing nothing, and you even hear statements about them "dumping" in gas! |
03-17-2011, 02:19 PM | #42 |
That must be the rare and expensive KR Wilson V-211 Stromberg Whacker!
03-18-2011, 08:09 PM | #43 |
the picture in post #35, how do you put intake manifolds on exhaust ports ? is it a special cam ? or cam timeing ?
03-19-2011, 01:59 AM | #44 |
04-05-2011, 10:44 AM | #45 |
Anyone know if Bud Calicutt got his car running better?
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
04-05-2011, 10:50 AM | #46 |
04-05-2011, 10:53 AM | #47 |
Simply put 2 94's or 2 97's are realy too much carburation for a 4 banger. Word to the wise. ken ct.
08-12-2013, 10:55 AM | #48 |
I was just reading the above and It's all good info. I'm wondering if any can help me out with this. This is what I'm running A Simmons supper power head 6.1 compression and a Ansen intake. When I lay off the Gas 45-50 mph it back fires or just running at that speed It will start to back fire. The jets right now are 47's. Or Is it timming?
Thanks |
08-12-2013, 11:16 AM | #49 |
Im not even going to get into this.Good luck ken ct.
08-12-2013, 12:17 PM | #50 |
To complicated!!
08-12-2013, 04:41 PM | #51 |
I would first think leaky exhaust, either manifold or pipe connection.
08-12-2013, 10:40 PM | #52 | |
08-18-2013, 09:48 PM | #53 |
Sure gets frustrating with the HAMB and Barn people. Ask a question on one and get referred to the other. There really are a some of us who have/want modified Model A's and don't want street rods or V8's. We just need to communicate with others who are like minded without a scolding from the purists on the Barn or the rodders on the HAMB who don't feel bangers are traditional hot rods. Rant over, now I feel better.
08-18-2013, 09:59 PM | #54 | |
08-18-2013, 10:10 PM | #55 | |
08-18-2013, 11:06 PM | #56 |
http://www.jalopyjournal.com/forum/s...d.php?t=821243
HI Klawockvet: Here is the Aug. Banger Meet on the H.A.M.B. you could ask your question there. Gary in MN. |
08-18-2013, 11:19 PM | #57 | |
