01-17-2020, 12:24 PM | #21 | |
Re: exchange 8ba cyl heads with 59ab
I'll take some pictures for shits and giggles . . . |
01-17-2020, 01:08 PM | #22 |
I, for one, would like to see them.
01-17-2020, 04:07 PM | #23 |
This works well for circle track. There are 4 inlets on the top of the heads but no pic of that.
It worked ok on the street once also but water flow was in the normal direction there. |
01-17-2020, 04:33 PM | #24 |
01-17-2020, 11:25 PM | #25 |
I would think that if you were to "port match" the water passages in the 59ab block to match the 8ba style heads you probably would not be able to use the earlier heads again if you ever wanted to.
