Old 06-04-2018, 10:41 PM   #1
LEM
LEM's Avatar
Default Tie rod too long
I installed a new tie rod in my 1929 roadster but could not achieve the proper toe-in measurement because I ran out of threads on the ends. I later measured the bent original (43") but the new one is 44" long. Question: are there different tie rod lengths for each model year?
LEM is online now   Reply With Quote
Old 06-04-2018, 11:20 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Tie rod too long
No, one size should fit all, although the spindle arms did change their distance a little.
Old 06-04-2018, 11:27 PM   #3
J Franklin
J Franklin's Avatar
A longer tie rod should allow more toe in.
Old 06-04-2018, 11:37 PM   #4
eagle
eagle's Avatar
yeah, OP said proper toe in, not that he couldn't get any toe in. If he ran out of threads he was trying to reduce toe in due to the tie rod being too long. My tie rod was bent up. It wasn't a big job to straighten it. I would say fix the original if at all possible.
-edit- re-reading this post I sound sort of short-tempered, didn't mean it that way
Old 06-05-2018, 12:21 AM   #5
J Franklin
J Franklin's Avatar
I see, he ran out of threads on the inside.
Old 06-05-2018, 05:18 AM   #6
Jim/GA
Jim/GA's Avatar
Yes, the tie rod length changed in September, 1928, at the same time that the spindles arms were slightly redesigned. It required lengthening the threaded tie rod from approximately 42-3/4" to 43-1/2".
So it sounds like your '29 roadster may be fitted with '28 spindle arms by a previous owner.
I hope this helps. Feel free to PM or email me with follow up.
Jim Cannon
"Have a Model A day!"
Old 06-05-2018, 09:59 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
Jim,
Off the top of my head..I think your backwards, best guess.
The arms that are closer too the backing plates take a longer tie rod..
Dudley
d.j. moordigian is offline   Reply With Quote
Old 06-05-2018, 11:41 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dudley,
I put on one of Arts' "T" shirts, BACKWARDS & no one EVEN noticed it--LOL
Willy Bill
"THE ASSISTANT GURU OF STUFF"
Old 06-06-2018, 09:34 PM   #9
trucker1
Could someone tell me the size and thread count of these tie rod threads? Glynn.
trucker1 is offline   Reply With Quote
Old 06-07-2018, 11:29 AM   #10
LEM
LEM's Avatar
The thread size on the ends of the tie rod are 11/16-24 and about 2" long.
One end is right hand threads and the other end is left hand threads.
The right hand threads are threaded into the left hand tie rod end fitting.
Old 06-07-2018, 05:35 PM   #11
redmodelt
redmodelt's Avatar
Do you have a dropped axle?
Old 06-08-2018, 01:17 AM   #12
LEM
LEM's Avatar
No I do not have a dropped axle. The roadster was restored about 20 years ago and I do not have the history on it. I am beginning to believe that it is a 1928 with a 1929 motor and transmission.
Old 06-08-2018, 08:32 AM   #13
BILL WILLIAMSON
LEM,
Would you consider having a welding shop cut a small amount from it & re-welding it?
The rod is hollow & a piece of round steel could be put in it, for safety.
Bill W.
Old 06-08-2018, 02:32 PM   #14
LEM
LEM's Avatar
Bill:
The rod that is too long is a new solid one. I could cut an inch off the right hand threaded end and then chase the threads down the rod one inch further. But I thank I will have the original hollow one straightened (I like original).
Old 06-08-2018, 03:02 PM   #15
trucker1
Thanks LEM for the info. Glynn
Old 06-08-2018, 06:50 PM   #16
Tom Wesenberg
Lay the original hollow rod in the V of a thick piece of angle iron, then use a block of wood and 3 pound hammer to straighten it.
Old 06-08-2018, 07:08 PM   #17
BILL WILLIAMSON
Tom,
Minervas' hollow one was bent by "someones'" damper, that had some HUGE shock on it. Removed & trashed the damper & pried the rod straight, on the car, with a 2 Ft 2X4. Found that the TOE-IN was PERFECT!
Bill Easy
Old 06-16-2018, 05:58 AM   #18
updraught
updraught's Avatar
https://www.brattons.com/tie-rod.html
http://www.mikes-afordable.com/product/A3281.html
https://www.snydersantiqueauto.com/tie-rod
https://www.macsautoparts.com/ford_m...nd-pickup.html
Take your pick
updraught is offline   Reply With Quote
Old 06-16-2018, 01:58 PM   #19
LEM
LEM's Avatar
Brattons is 44.0 long @ $19.00
Mike's is 44.0 long @ $14.95
Snyder's is 43.4 long @ $14.95
Mac's is 43.5 long @ 30.99
Smith & Jones is 44.0 long @ $17.00 ( this is the one I bought and is too long)
Bottom line- measure before you order!
