06-18-2017, 11:00 AM | #1 |
Two tooth worm installation
How hard is it to replace the two tooth worm gear on to the steering shaft at home. I do not have a press. I'd like some advise before I remove the steering column. I need to rebuild / repair mine. the box has a lot of play and the car wonders a lot. The steering box is all original. Thanks in advance
06-18-2017, 11:04 AM | #2 |
Re: Two tooth worm installation
It may be possible to replace the worm without a press, but it will be extremely difficult. You are going to be much better off either buying a new steering shaft with a worm already installed, or taking it to a machine shop to have it pressed on and off. Sometimes the aggravation isn't worth the money saved.
'31 40B '31 68C |
06-18-2017, 11:26 AM | #3 |
This link shows how to do it without a press.
The link didn't work, looks like this site blocked it. Bob Use this link, it goes to this site instead of the competition. https://fordbarn.com/forum/showthrea...highlight=Worm Last edited by Bob C; 06-18-2017 at 11:52 AM. |
06-18-2017, 11:41 AM | #4 |
06-18-2017, 04:50 PM | #5 |
We had a seminar a while back and I asked the question about putting the new worm on the shaft and was told to tap the shaft and use a bolt to pull it on. Works like a dream and doesn't hurt anything
06-18-2017, 05:17 PM | #6 |
06-18-2017, 07:56 PM | #7 |
At least some of the vendors now sell the shaft and worm separately after complaints from people like us. Until they went back to doing this, we had to buy a shaft with LHD worm fitted and a RHD worm, remove the wrong one and fit the correct one. I'm still amazed that they decided it was a good idea to only sell LHD worm already fitted to a shaft and no shafts alone.
