Old 07-10-2021, 06:30 AM   #1
32forddump
32forddump's Avatar
Default Rusty head
I purchased a rusty head and i sandblasted all the surfaces but the bottom. What is the best way to remove the rust from the flat surface before I move forward?
Thanks
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
Old 07-10-2021, 07:03 AM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Rusty head
Have it milled flat?
Bruce of MN is offline   Reply With Quote
Old 07-10-2021, 10:27 AM   #3
chrs1961815
chrs1961815's Avatar
It needs to be milled anyways since it is an original so I would sandblast the whole bottom and the inside water jacket too. Give it a good blow out with compressed air.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-10-2021, 11:12 AM   #4
Jim Brierley
Sandblast or sand the surface. If sanding, wrap the paper around a piece of wood that is flat. Don't use a file as they tend to bend if not held carefully. After cleaning, check for flatness. Using a quality ruler, such as a machinist rule, will tell you if it is useable as-is. Up to .006" is a tolerable number to be used without having it machined.
Jim Brierley is offline   Reply With Quote
Old 07-11-2021, 04:15 AM   #5
32forddump
32forddump's Avatar
Thank you all for your suggestions!!
