09-22-2018, 01:47 PM | #1 |
Changing king pins and bushings
Got my new pin's and bushing's today, want to know best way to remove the tie rod ends. I can get the fork from O Riley's , but it seems to me like hammering on the linkage is not a good idea. If I jack one tire up, remove wheel and do one side then the other, will that keep it more solid? How do you guy's do it, I've never done this job before and want to do it right without destroying something else. Al
09-22-2018, 01:54 PM | #2 |
Re: Changing king pins and bushings
All kinds of ways without the fork. Put it on jack stands and then without the nut on the tie rod end you can put pressure against it with a floor jack then crack the side of the steering arm were the tierod goes through with a hammer and it will come out pretty easy.
If the kingpins are rough that could be a whole nother bag of worms getting them out if you have never done it. |
09-22-2018, 02:55 PM | #3 |
Just looked at mine, the nut is on the top, so putting a jack under it will not work. This is on a 41 coupe, maybe it's different than what you have done before. Al
09-22-2018, 03:16 PM | #4 |
Use two hammers, one to back up the opposite side of the steering arm while striking the other side.
09-22-2018, 03:38 PM | #5 |
09-22-2018, 04:19 PM | #6 |
09-22-2018, 04:33 PM | #7 |
Use two hammers line 51 Merc says. One backs it up and the other whaps the socket which will cause the tierod taper to loosen.
09-22-2018, 10:06 PM | #8 |
I just use my inexpensive pickle fork. The miracle of the inclined plane. Done it dozens of times. No problems whatsoever. It's a good tool to have in one's kit.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
09-23-2018, 03:04 AM | #9 |
I don't like the pickle forks as they damage the boot which is an MOT test failure here in the UK.
I have a tie rod end puller. Actually more of a pusher. you put it over the end of the steering arm and turn a screw to push the pin out. This type works well: Mine is more like this: Just google tie rod separator and lots of choices should come up. Mart. |
09-23-2018, 08:17 AM | #10 |
Well that makes sense Mart. And the screw thread on those tools is also an inclined plane with a nice low angle.
09-23-2018, 09:45 AM | #11 |
I like the looks of that one Mart, no hammering, or damanging the rubber seal. I'll see if I can find one. Thanks .Al
09-23-2018, 09:51 AM | #12 |
I rented the tie rod/ball joint tool kit for free from AdvanceAuto. Believe Auto Zone also does.
09-23-2018, 10:00 AM | #13 |
The one in the upper picture is a good type for early Fords as it will get the tie rod end off the passenger side better than the one in the lower pic. (The forward one of the two holes).
09-23-2018, 10:11 AM | #14 |
What size is the tie rod, I found listings for 19mm and 21mm. Which one will fit my 41. Al
09-23-2018, 11:22 AM | #15 |
I ordered the top one since it's universal, sounds like a strong tool, thanks Mart. I'm having to take the spindles off to get the new bushings honed, BTW the new set of king pins I got from Speedway have hardened pins. Hope this get's rid of the shimmy. Al
09-23-2018, 11:58 AM | #16 |
When using the upper tool, I found that, to my surprise, if you load it up (tighten the screw) and let it sit for a minute or two, it suddenly pops loose. No need to tighten more and more til it breaks loose.
09-23-2018, 12:59 PM | #17 |
Reassemble with a dab of anti-seize.
09-23-2018, 01:46 PM | #18 |
Thanks for the help, I can't believe that at my age and working on cars all my life that I hadn't done tie rod ends, live and learn. Al
09-23-2018, 01:50 PM | #19 | |
09-23-2018, 02:20 PM | #20 |
Actually, you can get good tools like shown above from Harbor Freight
