Old 06-12-2011, 04:43 PM   #1
Pepsi Mechanic
Pepsi Mechanic's Avatar
Default slight smell of antifreeze at start up
Just wondering if there is anything to worry about .. When starting the AA cold (and only cold ) I have a slight smell of antfreeze .. no leaks .. no smoke ... etc. This engine runs great , has good compression etc. As far as I know she has never been apart ... Should I possible check the torque on the head bolts ? The truck is only used for car shows and the odd parade now and then .. She is never road driven ... Should I even worry about it .. the antifreeze smell goes away in a minut or so ( I suspect the coolant residue is in the exhaust .. that just my guess ... Need some advice .... Thanks Harry / Pepsi Mechanic
Pepsi Mechanic is offline   Reply With Quote
Old 06-12-2011, 06:12 PM   #2
bogdonj
bogdonj's Avatar
Default Re: slight smell of antifreeze at start up
I would keep an eye on it but wouldn't worry about it!
bogdonj is offline   Reply With Quote
Old 06-12-2011, 07:31 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, check the head nuts. I've been running an old used engine in my 28 while I rebuild the original engine. Last summer I pulled the plugs just to check the compression for the heck of it, then last fall I put my tool kit plug wrench to the head nuts and found a third of them a bit loose. I never smelled antifreeze and never had a leak, but I pulled then tight anyway.
Old 06-12-2011, 08:17 PM   #4
Pepsi Mechanic
what is the torque ?
Old 06-12-2011, 09:12 PM   #5
Tom Wesenberg
55 foot pounds. One at a time, back the nut off 1/8 turn, then with one smooth motion tighten to 55 ft. lbs.
I didn't have a torque wrench handy for mine, so I just tightened until I thought it was 55 foot pounds.
Old 06-13-2011, 05:59 AM   #6
Pepsi Mechanic
.... Thanks for the input ... I will check her over this week ... I kinda like the wrench method .. gives you a feel as to how tight she is ... last thing I want to do is break a stud
Old 06-13-2011, 09:14 AM   #7
Chris in WNC
Chris in WNC's Avatar
my solution would be to purge the anti-freeze from the system in good weather..........
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
