01-30-2020, 02:05 PM | #1 |
harmon&collins dual coil distributor
I have a new H&C dual coil distributor that I want to use, I ran one in the past with external resistors . generator was converted to 12 volts using external resistors. Should I use coils with built in resistors? Just for simplicity. Also the new distributor was built in the 50s are the condensers still good? Stan
01-30-2020, 02:21 PM | #2 |
Re: harmon&collins dual coil distributor
Replace the condensers and make it look like this one >
01-30-2020, 02:27 PM | #3 |
As for the condensers, have them tested to be sure. Many go bad from age.
01-30-2020, 03:39 PM | #4 |
If the condensers turn out to be bad, I make replacements that have proven to be very reliable and stable under all conditions.
01-30-2020, 10:19 PM | #5 |
Charlie ny |
