09-01-2019, 12:54 PM | #1 |
A head on B engine
what is involved? drill some steam holes? im thinking about using a higher comp A alum head on the B motor
09-01-2019, 02:46 PM | #2 |
Re: A head on B engine
Hi; My '32 B came with a Model A head and pump, ran fine. In fact it was a Model A "police" Ford high comp head..... a 'B' head. Check the gaskets for any changes. Newc
09-01-2019, 04:07 PM | #3 |
well this B has the C head on it, which is high comp I guess. just thinking about going A head so a waterpump is more avalable
09-01-2019, 04:41 PM | #4 |
The stock B head with the C on it is 4.6:1 and the stock A head is 4.22:1.
Bob |
09-01-2019, 05:15 PM | #5 |
yes I did know that. what I want to know is what has to be don't to use an A head on B block. thinking about using an aftermarket alum head for an A
09-01-2019, 10:35 PM | #6 |
Society of Speed google it- has been around 25 yrs, based in Ohio. Newc |
09-02-2019, 09:03 AM | #7 |
Between #2,3 there's 2 small holes, depending on the head, and gasket used those 2 holes may need to be plugged
09-02-2019, 10:51 AM | #8 |
09-02-2019, 01:35 PM | #9 |
Many years ago I ran a Model A cylinder head on a Model B engine in my 1929 Station Wagon with oversize tires for hard driving on sandy beaches. At the time my nephew was a hot rodder and he threaded bolts into the two steam holes that are in the block, then cut and filed them flat. Used the regular Model A cylinder head gasket, drove many miles over about 12 years, never had a problem.
09-02-2019, 01:46 PM | #10 |
I'm not a Ford Four Banger guy so the
steam hole doesn't compute with me. Can any of you guys fill us in? Thanks |
09-02-2019, 04:56 PM | #11 |
09-03-2019, 09:13 AM | #12 |
Ck out Vince Falter's site or try the A forum OR a search. Steam hole filling has been covered before.
Paul in CT |
09-03-2019, 09:51 PM | #13 |
vince falters site is wonderful. i believe its "the old ford garage"
09-04-2019, 05:57 AM | #14 |
Thanks. Will check it out.
09-04-2019, 09:36 PM | #15 |
https://www.jalopyjournal.com/forum/...-links.161498/
There is a monthly "banger" thread. Not sure it's still active. If not, the model A forum here is good. They know touring As and B motors. . Last edited by Tinker; 09-04-2019 at 09:45 PM. |
02-19-2020, 05:58 PM | #16 |
so its time. ive not had anyone say for sure it wont work or do it this way not that way. I can reach inside and see that if I drill the holes in the head the hit the water jacket.
im leaning to just drilling the holes to match |
02-19-2020, 06:56 PM | #17 |
If your motive is what you believe to the be the relatively availability of B water pumps, I believe that you've been misled. There out there in quantity.
02-19-2020, 06:57 PM | #18 |
Use the Model B gasket with either the B head or the high compression Model A head and the steam holes are covered so the problem is gone. I am basing this on all of the High compression Model A heads I have ever seen. I assume you are running this in a Model A, if not then what?
Charlie Stephens |
02-19-2020, 07:37 PM | #19 |
years ago when i put one of charlie yapps heads on my B motor i had leaks from those holes. had the head off twice. then called charle and he said "we always plug those holes" so, i did, problem solved.
02-19-2020, 08:11 PM | #20 |
