09-12-2017, 09:34 PM | #1 |
cab heater for 30 coupe
What was available for cab heaters in 1930? Pictures would be appreciated. Thanks
09-12-2017, 09:55 PM | #2 | |
Re: cab heater for 30 coupe
Charlie Stephens Last edited by Charlie Stephens; 09-12-2017 at 10:02 PM. |
09-13-2017, 01:52 PM | #3 |
Not to contradict Charlie, but depending on your climate, the exhaust manifold heaters as shown in his pictures may be plenty good enough...and are likely more readily available. Where I live in Connecticut, I drive my '30 Coupe year round with a heater very much like the Auto-lite in this pictures.
Look at your firewall, just behind the exhaust manifold. Don't be surprised if your car already has a hole there from somebody installing a heater long ago. Ken
Style beats speed any day, and with a lot fewer tickets. |
09-13-2017, 09:26 PM | #4 |
If you go with the heater manifold be careful of two things. One, depending on where you live during the summer you WILL want to remove it as it will shorten your condenser life and roast you at the same time. And two, make sure you get the removable top with the manifold and that there are no cracks or missing chunks where the intake manifold screws go. There were a myriad of makers back then and trying to find the missing cover may be darn near impossible.
Mike
09-14-2017, 08:05 AM | #5 |
I like the hot water heater
V4f |
09-14-2017, 08:41 AM | #6 |
Bill Italiano
09-14-2017, 09:58 PM | #7 |
I found that the exhaust manifold heater is far more effective - and brings the heat sooner - than the hot water heater in a Model A. Since the early Fords didn't have a pressurized system, the hot water never got as hot as needed in the winter simply because the radiator worked quite well cooling the engine water when it was cold out. Exhaust heaters were the opposite: The more you ran the engine, the hotter they got.
09-15-2017, 08:08 AM | #8 |
Stay with the manifold heater. It is all you need. If you install a water heater, look out when you have to work on the car and take out the floor boards. Big job taking all that apart every time the floor comes out.
09-15-2017, 09:56 AM | #9 |
There was also a heater called Southwind that ran on gasoline'
https://www.google.ca/search?q=South...espOzog4v6RDM:
09-15-2017, 02:10 PM | #10 |
Thanks fellas for the info.
09-15-2017, 02:51 PM | #11 |
I had one that was a manifold heater but it was plumbed so the heat came in from the floor board not the firewall. It saved cutting a hole in the firewall. There was even a couple that heated the back seat area. Check out pg 125 and 133 in "Those Wonderful UNAUTHORIZED ACCESSORIES For Model A Ford"
09-15-2017, 05:12 PM | #12 |
I have an Autolite in the ccpu and an Otwell in the tudor. The holes were there. I got the brand that lined up with the hole in the fire wall. The Otwell has a summer/winter vent cover. Great simple heaters for those chilly sunny winter days here in the northeast.
