Old 09-10-2018, 07:06 PM   #21
redmodelt
redmodelt's Avatar
Default Re: 1928 shift lever plate
The floor board would have just had a hole cut out for the gear shift lever to stick thru. There would have been just a plate to cover the access hole to grease the bearing without taking the floor out. The multiple disk clutch was used up to Nov 1928 and would have had a crossover with the pistol grip center parking brake lever.
Old 09-10-2018, 08:27 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
The picture of the 3 covers on the green background is my picture of my 3 covers.
Another way to tell a multiplate is the 3/4" pedal shaft, while the single plate has a 7/8" shaft.
Old 09-10-2018, 09:12 PM   #23
Bob C
Here are some original floor boards, just disregard the two small round holes.
Bob
File Type: jpg xFloor Board (upper) version 1 back.jpg (26.9 KB, 28 views)
File Type: jpg xFloor Board (upper) version 1 front.jpg (31.3 KB, 20 views)
Old 09-10-2018, 09:32 PM   #24
sailorcowboy
sailorcowboy's Avatar
Thanks Bob C,
I was googling so many floor boards tonight I think I will dream about them all night long. This looks like the truck floor boards I found in thread "Pictures of my floor boards". The only thing different for my 28 would be the two small holes that I presume is a different config for the truck? hydraulic lifter, starter??
I will use the ideas in the "pics of my floor boards" to make my own. Tom Wessenberg you mentioned you found the correct dovetail router bit for this job?
I need to dust off my router and start clearing the cobwebs from my planer as well!!!
Thanks so much to all, for the input today. This was great fun
Tim
Tim
1928 Sport Coupe
sailorcowboy is offline   Reply With Quote
Old 09-10-2018, 09:48 PM   #25
Bob C
Here is a link to a real good thread on the early floor boards.
http://forums.aa-fords.com/viewtopic...t=floor+boards
Bob
Old 09-10-2018, 10:15 PM   #26
sailorcowboy
Excellent stuff Bob C - thanks!
Tim
1928 Sport Coupe
Old 09-10-2018, 10:47 PM   #27
denniskliesen
denniskliesen's Avatar
Here's an end view of the tongue and groove in the solid wood floorboards.
denniskliesen is offline   Reply With Quote
Old 09-11-2018, 09:24 PM   #28
sailorcowboy
Thanks dennis. Great view of the end. I have so much to go by to get decent floorboards.
thanks to all!
Tim
1928 Sport Coupe
