Old 03-17-2019, 05:27 PM   #1
jwaldrich
jwaldrich's Avatar
Default 1940 LaSalle Fuel Starved
1940 322 CI was running sweet when all of a sudden it coughed and died. I've determined that it wasn't getting any fuel so I purchased and installed a rebuilt fuel pump and "no joy".
Poured gas in the carb and she fired right up and dies when the gas is gone.
Disconnected the output line on the new pump, cranked it and no gas getting through the new fuel pump. Car has roughly half a tank so not out of gas.
Bought and installed an electric fuel pump (inline) bypassing the mechanical one. STILL no joy. It isn't getting gas to the carb.
Blew lp air into tank and fuel sprays out of the feel line from the tank. Blew back the other way as well to ensure no blockage.
Ideas?
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 03-17-2019, 06:16 PM   #2
Bob C
Default Re: 1940 LaSalle Fuel Starved
I had a flex line between the fuel pump and metal line come apart inside one time and you could blow back to the tank but not the other way.
Bob
Old 03-17-2019, 08:07 PM   #3
paul2748
paul2748's Avatar
Check all fittings for tightness. It might be sucking air instead of gas.
48 Ford Conv
56 Tbird
54 Ford Victoria
paul2748 is online now   Reply With Quote
Old 03-18-2019, 05:00 AM   #4
fortyonerag
fortyonerag's Avatar
Hole in the pickup tube inside the tank?
fortyonerag is offline   Reply With Quote
Old 03-18-2019, 07:19 AM   #5
jimTN
you are getting air in the line somewhere between the pump and the gas in your tank.
Old 03-18-2019, 12:06 PM   #6
jwaldrich
jwaldrich's Avatar
Will buy a rubber fuel line today to run from the tank to the fuel pump and see what happens.
John from Kapowsin
T&A Guy
Old 03-18-2019, 12:17 PM   #7
Ol' Ron
Ol' Ron's Avatar
What kind of electric pump did you buy. I've had the same problem and found the line going into the pump must be lower than the pump. I then put alittle air into the tank to prime the pump. I made a lupe that is about 5" below the pump.Works fine now.
Old 03-18-2019, 12:24 PM   #8
jwaldrich
jwaldrich's Avatar
Originally Posted by Ol' Ron View Post
What kind of electric pump did you buy. I've had the same problem and found the line going into the pump must be lower than the pump. I then put a little air into the tank to prime the pump. I made a lupe that is about 5" below the pump.Works fine now.
I wondered about the elevation of the pump. The line feeding the pump was below the pump. I finally got it to "trickle" but not enough to run the car.
I mounted the pump on the fender well so it was stable. Not quite as high as the tire is tall.
John from Kapowsin
T&A Guy
Old 03-18-2019, 03:33 PM   #9
JSeery
JSeery's Avatar
Works best as close to the bottom of the tank as practical.
Old 03-18-2019, 05:31 PM   #10
Ol' Ron
Ol' Ron's Avatar
Yep JSeary has it again
Old 03-18-2019, 09:47 PM   #11
4dFord/SC
4dFord/SC's Avatar
Mine works well mounted to the rear cross member.
4dFord/SC is offline   Reply With Quote
Old 03-18-2019, 09:50 PM   #12
Tinker
Tinker's Avatar
Might want to also replace your fuel line after the tank clean or replacement. Nothing like a fresh line. It's not too expensive if you do it yourself.
Old 03-18-2019, 10:53 PM   #13
Mike in AZ
Mike in AZ's Avatar
Plumb a line to the pump from a can of gas. If you get a flow of gas from the pump, then problem is between pump and tank. I hope. Good luck. Mike
Mike in AZ is offline   Reply With Quote
Old 03-18-2019, 10:56 PM   #14
Tinker
Tinker's Avatar
Your picture looks familiar, the highway man. Any relation?
Old 03-19-2019, 01:38 AM   #15
T Scott
I was told that with a leaky diaphragm, the laSalle pumps could dump fuel into the crank case. I'm not sure this is the case, but since the bottom half of the pump is a vacuum booster for windshield wipers it is probable that there is no fuel drain to prevent such fuel dump. Frankly, I never inspected my 37 laSalle fuel pump for a drain.
In any event, I installed two Facet low pressure electric fuel pumps, filter and pressure gauge on the frame rail in the engine bay. They are in series with one being a back up.
No problems drawing fuel, no carburetor flooding and easy filter access.
T Scott is offline   Reply With Quote
