11-10-2017, 01:15 PM | #21 |
Re: Gas tank spigot removal
Vacuum pumps are used on A/C all the time to remove moisture. I had a taillight on a modern car that was sealed, the seal broke and got moisture inside. I taped a vacuum hose to it and ran the vacuum for about 3 hours and it was dry inside. Resealed it and has been dry since. I can't recommend doing this on your fuel tank but if you did, I'd be very careful about how much vacuum to use. You don't want to collapse the tank.
11-10-2017, 02:01 PM | #22 |
Hardware/Plumbing Stores have a NEEDLE type valve, that fits perfectly in place of the original valve! ONLY about $4.99. I've used them.
Bill Plumber
11-10-2017, 02:06 PM | #23 |
I have not be able to remove the fuel shut off valve. The leaf blower pushed out all the standing water.
11-11-2017, 10:20 AM | #24 | |
11-12-2017, 10:30 PM | #25 |
I first washed out the tank with oil eater. This removed the goop from old gas. Then I tried alcohol in the little water in the bottom. That mixed with the left over water and flushed out much of the trapped water. Per your suggestion, I added a couple of cups full of acetone and waited about 3 hours. I drained that out and there was color to the mixture, meaning the acetone was working on the rust and what ever was left in the tank. I removed the drained liquid from the garage. Tomorrow I will see if the tank is dry inside. If so, I plan to pour a bit of Evaporust in the tank and drain it out to be sure all the water is gone. Then fill the tank with Evaporust and let it sit awhile.
11-14-2017, 02:47 PM | #26 |
11-15-2017, 11:30 AM | #27 |
I'm going to drain out the Evaporustte this morning and I hope the rust is gone.
11-15-2017, 03:16 PM | #28 |
Evaporust drained out and saved. The first 3 jugs of it were very dark. thereafter it lightened. up I shook the car the best I could. I guess I should have tired to stir the mix with a paint stick. Tank fully rinsed and now drying. I don’t know it it has to be fully dried. Then sometime refill with Evaporust and drain out again
11-15-2017, 05:09 PM | #29 |
With cooler temperatures I have found that longer soak time is needed. 80-90* 24 hours would be fine. I wouldn't have worried about some water in the tank as Evaporust when it evaporates you add water to it.
