#1 |
Can anyone tell me where the cowl vent drain tube routes in a '36 phaeton?
I have a nice new tube hooked to the drain fitting, but can't find a reasonable place for it to exit the cockpit.
Houston, Tranquility base here. The Eagle has landed. |
#2 |
There is a hole in the firewall between the choke and throttle rods that the hose goes through. Normally ends about 2" into the engine compartment. I extended my hose down along the engine to allow water to drain off the firewall.
#3 |
In my car that hole is used by the wiper vacuum hose. Is that same hole supposed to pass the cowl drain? Doesn't look big enough for two lines and a grommet.
Thanks, John
#4 |
The wiper vacuum hose passes through the hole of the wiring loom along with the temp gauge line.
#5 |
John-
The wiper hose is routed wrong. It should go through the main wire loom hole. Note picture. Tom |
#6 |
Note the chromed vacuum line in the middle of the picture. The persons doing the rebuild in the mid-70s apparently had a complete aircraft fab shop available. Thanks again, Tom, John
