02-18-2018, 09:28 PM | #1 |
1937 Steering-Box Parts
I just rebuilt a dandy 1937 steering box that I’m installing in my ‘36 sedan. The box is ready to go, but I’m short a few important components related to the headlight switch and horn. Can someone please show me what parts I’m missing (part numbers?) and where I can get them? The steering box is ready to go in the car aside from these AWOL pieces, which I’d like to have ready before completing the install.
And here are some of the parts I have from the original '36 box. I also bought a new bail for a '37 Ford (the shiny, cadmium-colored one). Now, for proper fitment, I opted to put a new steering-box bracket in, which meant the old one had to be removed. Drilling and grinding the four rivets that attach it to the frame is an easy-enough, if annoying task, but beware of the hidden spot weld! This may be common knowledge, but rather than attempting to drill it out, which would have been a terrible game of whack-a-mole since it was impossible to see, I bolted a piece of scrap steel to the bracket and worked it back and forth a few times until the weld gave out. Fortunately, it broke off cleanly and with minimal effort. Give this a shot if you’re attempting the same steering-box swap. Thanks, guys! |
02-18-2018, 09:36 PM | #2 |
Re: 1937 Steering-Box Parts
The Green Book list all of the parts and part numbers. There are illustrations as well. Here is an example.
02-18-2018, 10:27 PM | #3 |
Many thanks for taking this project on and posting pictures. After I get the smoke put back in the wires and get my '36 5W Cp rewired, I will be taking on the installation of hydraulic brakes and upgrading the steering just as you have.
A few questions, what did you do about the steering wheel lock? I have the '37 column as you have shown in your picture. I have looked in Mac's and Drake's book and do not see the lock collar anywhere. Since you did not remove the engine, what kind of grinder did you use to reach straight down and grind off the two top rivets? Steve |
02-18-2018, 11:25 PM | #4 |
it looks to me like you are only missing the spring3642, and the two pronged thingy that turns the switch 3643, and the clip 3644 that holds it all up there.
02-19-2018, 05:51 AM | #5 |
Well, the whole light switch assemble is not shown in the photos for starters.
02-19-2018, 08:45 AM | #6 |
02-19-2018, 10:27 AM | #7 | ||
As for the rivets, I center-punched them, then drilled 'em in two stages to clear out some of the bulk, then I took the heads off with a Ryobi angle grinder similar to this one: https://www.homedepot.com/p/Ryobi-6-5-Amp-4-1-2-in-Angle-Grinder-AG4531G/205558214 The rivets are tight, likely swelled between the various metal thicknesses of the frame, but not overly difficult to remove. Just take your time. Quote:
Yeah, I'm trying to ascertain what exactly I need to get my hands on. To attach the headlight-switch/horn assembly I'm guessing I need parts 78-3569 and 78-3597 but I'm not exactly sure... |
02-19-2018, 10:35 AM | #8 |
See if any of these help (not 37 box). The first one is 39-40 and the second one 28-36, but the parts are similar.
You already have the 3597 part! It is the plate with the tube on it. It is going to help a lot if you understand what these parts do. The tube goes up through the steering box to the top. The shaft from the steering wheel switch goes down through it and out the bottom of the box. The tube keeps the lube from pouring out the bottom of the box. The tube must have a good seal to the plate or it will leak (this is a common problem). Spend some time figuring out the function of each part and think that will help a lot!! I would guess that you might be able to use your 36 parts on the exterior of your 37 steering box, but not positive about that. Last edited by JSeery; 02-19-2018 at 10:50 AM. |
02-19-2018, 12:28 PM | #9 |
In the first pic its hard to tell how the bracket is but appears correct.A little cleaning to see would help.The bracket in second pic is not correct.37 ,38, 39 are all the same.
