Old 10-24-2019, 09:12 PM   #21
Railcarmover
Default Re: No compression all cylinders
Originally Posted by Chuck Dempsey View Post
'Soft as cheese...' - I believe it.
I looked at the body for something to salvage..but no dice,ended up buying the chassis..fresh engine with nice babbit,transmission and rear end excellent,mitchell OD,pro built backing plates with woven shoes and cast iron drums,front axle tight,f100 steering box..all for half of what a new mitchell costs.When I tore it down and saw what I had I was giddy as a school girl..
Railcarmover is offline   Reply With Quote
Old 10-24-2019, 09:54 PM   #22
Fred K-OR
Fred K-OR's Avatar
Originally Posted by Fullraceflathead View Post
I’ll bet the valves are sticking open from old varnished fuel residue.
This is my guess also.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 10-25-2019, 06:38 AM   #23
desotoguy
I'm sure you have checked, but I will ask anyway, is your compression gauge operating properly?
desotoguy is offline   Reply With Quote
Old 10-25-2019, 07:23 AM   #24
chap52
chap52's Avatar
Don't spend a lot of time "guessing". You're going to tear it apart anyway, right?
If you don't plan om tearing it down then you can spend a lot of time and money chasing the "gremlins"... Either way, "Enjoy the adventure"... Chap
chap52 is offline   Reply With Quote
Old 10-28-2019, 04:54 PM   #25
31deluxe
Took the valve cover plate off today and saw 4 sticking valves. Took the head off and with a little persuasion got all valves freed up and moving. One stuck valve in each cylinder will certainly give zero compression in all 4 cylinders
31deluxe is offline   Reply With Quote
Old 10-28-2019, 05:07 PM   #26
Synchro909
Synchro909's Avatar
I don't like to say I told you so but I will. Pls have another look at post #3.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-28-2019, 06:27 PM   #27
Patrick L.
Patrick L.'s Avatar
I guess the valves really weren't going up and down.
